Question about Mantis 2-Cycle Tiller
Ratio gas and oil should be- Mantis two-cycle
I was just given this wonderful mantis two-cycle rototiller.
I just don't know what ratio gas and oil mixture should be.
Same as my chainsaw....my weed-wacker???
Can you help?
vincob
  • 718 Answers
SOURCE: Have not used the Mantis for one year. Cannot get
clean carb!!
Posted on Aug 21, 2010
SOURCE: what is the gas/oil mix on a Mantis 2 cycle
50:1
Posted on Jun 08, 2011
wolfwizard11
  • 5 Answers
SOURCE: Mantis 2 cycle - tines lose power.
I had this problem today. Loosen the flange bolt. Pull the engine off and check that the hex end of the shaft is lining up with the clutch pad in the engine-that it seats properly. Then make sure the shaft is seated all the way into the worm gear and put the engine back on. You will probably have to wiggle the shaft until it seats into the clutch. Tighten the flange bolt when the engine is seated flush with the worm housing (with no gap). That's all I did and the power is back up. Hopefully you still have your manual with the parts blow-up. (page 29?) BTW, have you checked that the wormgear is greased?
Posted on Aug 04, 2009
  • 881 Answers
SOURCE: WHAT IS THE GAS AND OIL RATIO FOR A 2 CYCLE MANTIS
IT is 200ml to 5 ltrs of unleded petrol
Posted on Sep 24, 2009
  • 3 Answers
SOURCE: Mantis Tiller: twocycle engine,mixture oil/gas for
40 to 1
Posted on Dec 02, 2009
Mantis tiller fuel oil ratio
Hi ANON, in my mantis i use a ratio of 40:1 the one being oil.
Jul 11, 2014 | Mantis Tiller
How to change mantis rototiller clutch
Dissembling the clutch uses special tools to prevent damage to other parts. A trusted shop would be able to do this cheap, then you can reassemble without special tools
Apr 19, 2013 | Mantis 2-Cycle Tiller
Need to know oil / petrol mix for Mantis 2 stoke Tiller
it is a 50:1 gas:oil mix. I'd also strongly recommend adding a fuel stabilizer to the mix, as a tiller has a tendency to sit for long periods without being used. Good luck!
Nov 17, 2012 | Mantis 2-Cycle Tiller
How much gas to mix the oil in?
First check that your Mantis needs an oil/gas mixture, most of the newer Mantis tillers have four-stroke motors meaning they have oil in the crankcase and use straight gas. If your Mantis needs oil mixed in the gas use a 50:1 ratio. That's usually 2.6 ounces of two-cycle oil (it's sold in bottles that size) to one gallon of gas but read the oil bottle to get the proper mix ratio.
Sep 08, 2010 | Mantis 2-Cycle Tiller
What are the gas settings for the mantis 2 cycle engine
The ratio is 50:1. 2.6 ounces of 2-cycle engine oil to 1 gallon of gasoline. Convenient, pre-measured bottles of premium 2-cycle engine oil are available via our on-line shopping on link below.
http://mantis.com/store/viewitem.asp?idProduct=1478
http://mantis.com/store/viewitem.asp?idProduct=923
Good Luck and please rate 4 thumbs up for the free answer.
Jun 23, 2010 | Mantis 2-Cycle Tiller
White smoke honda mantis rototiller
You're okay the white smoke is the oil burning off the muffler. In time it will stop, just park it somewhere and let it run until it's done. If the problem persists check your air filter and make sure it's not stained with oil, if so you can wash the foam part with soap and water but the paper will need to be replaced. (DO not put foam back on unit until dry.) The oil level should be up to the bottom lip of the dipstick access when the engine is evenly horizontal.
Apr 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Gas mixture 50/1 how do I get a 50/1 mix?
2.6 oz of 2 cycle oil to 1 gallon of gas. But I would suggest you mix it at a 40:1 ratio, which is 3.2 oz 2 cycle oil to 1 gallon of gas. Unless it is a piece of equipment bought at a dealer it is made differently than one made for a big box store.
Dec 14, 2009 | Mantis Garden
What is the correct oil/gas mix ratio?
The 2 cycle needs oil and gas mixed while the 4 cycle needs the oil changed every 10 hours of use. 2 cycle is 28:1
Jul 03, 2009 | Mantis 2-Cycle Tiller
Where do you drain oil on honda gx25 mantis
jj505 has good and bad information.
Honda GX25 is a 4 stroke motor, with oil lubricated crankcase.
Oil drains out the filler.
Oil and gas do not mix on this four stroke.
The PDF below is the Honda manual.
http://www.smallenginewarehouse.com/images/manuals/GX25-35.pdf
Apr 12, 2009 | Mantis 4-Cycle Tiller
Mantis 2-Cycle Tiller Logo
391 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
