Question about Dryers
Electric dryer won't heat. Continuity is good on
Kenmore electric dryer won't heat. Continuity is good on heater, sensors, fuse, etc.
  • 46 Answers
Make sure that you have 230volts at your receptacle. Most dryers will run the motor and controls off of one leg of your 230volt outlet or 120 volts but require 230volts to operate the heating element. As a previous service man I can't tell you how many times people called on a dryer problem when the problem was in a breaker.
Posted on Jul 03, 2010
I have a Kenmore fabric care 220 dryer cleaned the left side sensor started to heat went cold again
Heating elements could be going bad. Or the high temp fuse is out. Check the fuse for continuity and inspect the element for any breaks in the wiring
Jul 28, 2015 | Kenmore Dryers
Kenmore 70 series dryer won't heat
Post the model number for clarity. These tests should only be attempted by competent service personnel. Do you actually have 220 power? Are both legs of circuit hot...at 120v? While dryer is unplugged from power, check the heating coil for continuity. Also check continuity to ground from each end of heater (should not have continuity to ground at both ends). Also there should be power to the heating element when activated.
Mar 14, 2012 | Kenmore Dryers
Dryer is running, but heat will not turn on
There are several things that can prevent a dryer from not heating.. Unplug Power Before checking.
Electric Models
1- Power- Your dryer runs on 220volts. 110 runs the entire dryer and 110 runs just the element. Your breaker may have half tripped. Check to see if you are getting the correct amount of power by using a ohm meter. Also check the power cord for burn marks on the plugin and the cord itself.
2- The thermal fuse can prevent this from heating. The thermal fuse is a sensor on the blower housing the measures the temperature of the air. There is a cycling thermistat near the thermal fuse. If the dryer temp gets over 190-220 degrees the thermal fuse will blow to cut power to the element to prevent fire. You can test this by using a continuity tester.
3- High limit and/or thermal cutoff. These are both sensors on the heating element housing. Thermal cutoff is at the top and the high limit is near the bottom above the heating element connectors. Test these with a continuity tester.
4- Heating element- Just below the high limit on the heater housing. Test for continuity.
5- Motor- The motor has to reach a certain rpm to activate a sinfrigrial switch inside the motor. If the rpm is not reached it will not allow current to go to the element.
6- Timer- Make sure you are trying this on timed dry. Sometimes people use air fluff and forget to change it back. The timer could also not be sending current to the heater.
Gas models
1- Electric ignitor- Inside the flame tunnel inside of dryer near where gas line hooks up. Usually if it glows than it is still good but check to see if it is sending and amp signal to the heat coils.
2- Heater coils are two valves that open up when the ignitor send signal saying the ignitor can ignite the gas. Heat coils will not open to send gas if it does not receive a signal from the ignotor. They look like two round disk with two wires running from ignitor.
3- Flame sensor- Change if you change the heater coils. The flame sensor could not be detecting the flame inside so it shuts down the ignitor.
4- Motor- See above
5- Timer See above
If you have any further questions or need further assistance please feel free to comment me back.
Jul 27, 2011 | Kenmore Dryers
I have a Kenmore 110 Clothes Dryer. I live in an old house and it has fuses instead of breakers. The other day a fuse blew and the dryer stopped as did a television and a space heater. I replaced the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg YOu may also need to check the fuse block again it takes two fuses to run the dryer
Feb 10, 2011 | Kenmore 63942 Dryer
My Kenmore 400series 6942 electric dryer works, but doesn't get hot. Pulled the heating element had it tested. It shows good. Had three other relay/fuses tested. They show good. It has to be easy enough...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpg if there is no heat then one of the thermal fuses is bad you will need to check the continuity on them and replace the one that does not have any continuity
Jan 20, 2011 | Kenmore 400 6942 Dryer
Kenmore electric dryer not heating
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 20, 2010 | Kenmore 63942 Dryer
Kenmore electric dryer model 68702894 turns but no
The heater element may have failed - however, first check the Thermal limit fuse on the rear of the machine (silver disc held by 2 screws). Check for continuity.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 28, 2010 | Kenmore 60172 Electric Commercial Dryer
Dryer does not heat up. What can it be, and how
If it is an electric model then look for restricted venting and check the high limit mounted on the heating element and the element itself for continuity.
If it is a gas model check the flame sensor and ignitor for continuity. Check the blower housing duct fuse for continuity...read more
Oct 30, 2009 | Kenmore 64652 Electric Dryer
110.67832794 dryer will not heat
Check the thermal fuse. No continuity means a bad fuse. Part costs around 10 bucks no more.
Jun 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
