Question about Kenmore 22422 Top Load Washer
My washer over flows - Kenmore 22422 Top Load Washer
  • 23 Answers
Your pressure switch is either stuck or the tube is clogged. on the back of the front panel there are two screw in slots. undo those then pull on the panel foward and up. you will see the clear hose pull the hose off and blow into in also pull the knob of the cycle size switch and there is a little clip you will lift up and switch the switch out and then blow and **** on that to clear it up. then put it all back together and this should help you out
Posted on Jul 03, 2010
What does Code nf on washer machine Samsung vrt model mean
NF indicates no water flow. This could mean that the incoming water valves were shut-off, the incoming water flow is low, or that the washer didn't detect the water flow into the washer correctly. If the drain hose is too low, the washer could fill and drain simultaneously. This can also cause the problem.
First if the washer is not getting any water, then check your shut-off valves and the hoses. Disconnect the hoses from the washer and place a bucket under them. Check the flow by turning on each valve for a bit. Clean or replace the filters at the shut-off valves and in the washer. Consider replacing the hoses. Some anti-flood hoses will reduce the water flow if they detect leaks. Make sure that the hoses are not kinked. If the water flow is good at the shut-off valves, then the inlet valve may have failed in the closed position.
If water is filling the washer, then the problem is in the water flow detection system. This could indicate the small reed switch is damaged, the air tube to the reed switch is clogged or that tube has a hole in it. Some washers check for fill by the change in the drum weight. This signal may not be reaching the control unit due to a problem with the sensor or the wiring.
If the washer is filling and draining, pull your drain hose up. It is below the washer fill level. This creates a vacuum that will drain the washer.
I hope this helps.
Aug 25, 2017 | Samsung Washing Machines
What is a flow meter in a f/l frigidaire washer
I appreciate your post, greg aguilar!
I understand that you have a question about the flow meter on your Frigidaire washer. Typically, a flow meter monitors the amount of water being released into the washer. I hope this information has been helpful to some degree. -Matt
Nov 21, 2014 | Frigidaire Washing Machines
Water doesnt flow through my pressure washer when the enging is running
But, does it flow through when the engine is off?
If no water goes through either way, it can be as simple fix as cleaning the noozle. Remove the noozle, or the gun, and finally the out flow hose. If water flows through, start adding components from there. Also make sure that your noozle is turned on with full flow.
May 04, 2014 | Briggs & Stratton Pressure Washer...
FH error on display
An FH error usually means low water flow into the washer. This can be caused by debris in the filters between the intake hoses and the washer, closed water valves, low water pressure or a problem with the system that checks the water flow.
Some intake hoses when they detect a leak will seal themselves. So you may want to replace them. Shut off the water valves and remove the hoses from the washer. Check the filters for debris. With a bucket under the hoses, open the valves and check the rate of water flow. You may want to check the filters on the valve side of the intake hoses after turning the valves to off again. If water flows into the washer and then into the drain, reset the drain hose. The outlet of the hose should be above the water level in the washer. Otherwise, the water will suction out of the unit.
If these parts are fine and there is still no water flowing into the machine, the intake valve is faulty.
If you are getting the error when the washer is full of water, it's the pressure switch or the flow meter. In a few cases, the cause is actually damage to the air hoses connected to the pressure switch. If one of these thin tubes is leaking, the pressure switch will not work properly.
I hope this helps.
Dec 12, 2012 | Kenmore Elite 45986 Front Load Washer
Hi iv got 2 dirtblaster lance both doesn't work but does in friends whats the problem
those rely on "flow-rate". The oriface is sized for a certain flow-rate so it may be that your washer does not produce enough flow -- but your friend's washer does. Flow-rate is typically measured in GPM or LPM. With most of the commercial makes (brand), you can buy a rebuild kit and size it smaller than the original, causing it to match your pressure washer's flow-rate. To do this, however, you would need a vender to figure out which make it is -- then, if he knows the flow-rate, he can reference the orifice size and sell you the proper rebuild kit. You can expect those to cost between $20 and $40, generally.
Don
Feb 28, 2012 | Garden
I get an F H code. I bought a new inlet value which fixed the problem for about two weeks. I then installed the old one wich lasted another 2 weeks. How can I find and fix the correct problem. Maytag ...
As i suppose you know by replacing the water inlet valve that the F-H error code means now water was detected entering the washer. having replaced the water valve,one thing you should check,espically if using"aqua flow flood stop" braided steel inlet hoses from the house water supply,is if water is flowing through the inlet hoses into the washer, if your using that type of hose from the faucet they have a problem in them and the internal flood stop device inside the hose fails and even though the water faucets are on no water is getting into the washing machine. Also or even if using those type hoses disconnect them from washer and check for water flow through them when not connected to washer. If water flow is good into washer replace this part called the flow meter part # W10110225 it measures and tells the control that water is coming into the washer. It the flow meter can of course be purchased where you got the water inlet valve.
Good luck,
Gene
Aug 19, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
Why doesn't cold water flow into the washer through the Smartwater filter? When my Maytag Performa's Wash/Rinse temperature dial is set on Cold/cold no water flows into the tub. But when I set it on...
Hi .. I would first check the supply valve at the washer to be sure that it is open. if it is open , you can check the flow by shutting it off, removing the supply hose, opening the valve slowly and observing the flow. You might need a small bucket here. If you have water flow here at the washer supply valve, then the problem is inside the washer control.
Apr 18, 2010 | General Electric GE SmartWater Household...
Low cold water flow into washer tub
ck your screen inside the valve where the hose connects to the washer
Jan 09, 2010 | Washing Machines
Washer stops and has a flashing H F on it.....i have to press cancel and restart the washer....
ckd to be sure all screens in both ends of fill hose and inlet valve are clean if you have good water flow into washer suspect flow meter bad ..remove the three screws along back edge of top slide top back and off on left side there is a small round device with hoses into and out of it and 2 wires attached ..this a flow meter and detect water flow into washer ..small switch in unit has been known to cause issue..try tapping flow meter with screwdriver handle if corrects problem meter problem verified.. if not may still be bad and just can't budge switch with tap
Aug 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
