Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
Power overload, won't turn on - Bunn Margarita Machine Ultra 2 Slush Granita Maker
  • Bunn Master
  • 2,237 Answers
If the display won't come on, replace the fuse with the correct size. they are located inside the machine. remove the left panel.
Posted on Aug 25, 2010
Technics amp sux520d won't turn on
Have you checked the internal fuse? If that has blown suspect an overload in the power amp stage, mostly caused by short circuit transistors or other devices.
Jun 22, 2013 | Audio Players & Recorders
No power no lights won't turn on
start with the battery and make sure its charged and ok..then go to fuses and look there some vehicles have fuseable link wires in the system that fail due to corrosion and overloading..check all cables connectors and wires for burnt or broken issues.. get a battery charger and connect it to the car if now power anywhere..see if the battery is dead or needs replaced entirel..see if lights work when charger connected..if so battery needs charged or replaced..good luck..repost please thnx
Jan 17, 2013 | Cars & Trucks
Unit won't turn on
If the overload indicator is lit, the most likely cause is there are more devices plugged into the UPS than is can support. Try unplugging all devices but one and see if the unit functions normally.
You can then try to figure out how many is too many.
Dec 04, 2012 | APC Back-UPS RS BR1500-IN (BR1500-IN) UPS...
Goulds pump model BGR75 won't reset. Any tips.
If the motor runs but keeps tripping the overload, the motor is bad or the motor is under a big load. Does it pump water? If not, check the impeller and see if there is anything wrong with it. If it does pump water and the motor trips overload, the only thing left to check is the overload. Check the motor's amp draw and if within specs, replace overload. If amps are too high, replace motor.
Aug 22, 2012 | Plumbing
Fan won't run / won't cool
It may have a faulty compressor relay or overload, best to change both at the same time. It's either that or a bad compressor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Jan 06, 2018 | Kenmore 73055 Air Conditioner
After power surge aquos tv won't turn on
hi ther is a overload fuse on the psu board which will blow after a surge of power but to get to it you will have to take the back off
Nov 09, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
The craftsman model 137-248880 table saw won't power up. The breaker popped. I waited for it to cool, blew out all the dust from the motor and it still won't power up. The blade turns free so I...
Your electric motor probably has a flat spot ... give it a tap .. And try to power up.. I had that happen to a drill... I had to unplug it.. Uncover the motor and physically rotate the motor . Also the other problem area is the trigger (switch). May be worn.
Jan 11, 2018 | Garden
My AVR 2700 standby light is on and will not switch over to digital. I have no sound!
If it won't turn on it won't do anything at a higher level of function.
Perhap it's self-protecting.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 22, 2011 | Denon AVR-2700 Receiver
The receiver is flashing. Protect. And it want turn or program a station, what's. Wrong. With it
If it won't turn it won't do anything else.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 17, 2011 | Kenwood Audio Players & Recorders
Open Questions:
See all Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions
Kitchen Appliances - Others Logo
195 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Jerry Greenberg
Jerry Greenberg
Steve
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
