Question about Aube Technologies Aube 7-Day Programmable 40-500w Light Timer Switch
My house has a T1033A which controls the bathroom fans. There is no display and even when I turn the unit to the off position, I cannot switch the fans on. Is the unit shot? I can't determint which breaker is the one for it. Is there a re-set switch like I have for my no-fault bathroom plugs?
Open following link to identify timer and download manual:
http://waterheatertimer.org/Aube-timers.html
The reset button is small round button and can be pushed with toothpick or paper clip.
If reset doesn't restore timer, then timer is probably shot.
Also check all breakers to make sure one isn't tripped.
To test which breaker controls timer, open up box so you can test wires, and then use electrical tester and process of elimination to identify correct timer.
Add a comment and say if this is new installation or if timer suddenly stopped functioning.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 22, 2011
Where can I buy the Aube 7-Day Programmable 40-500w timer
You might be looking for T-1032 or T-1034 500watt timer
Identify model number on following link, and then google-search that specific model.
Link to instruction manual appears for each timer.
http://waterheatertimer.org/Aube-timers-and-manuals.html
Honeywell Aube in-wall timers can be used for single-pole or 3-way applications.
Look at instruction manual carefully for 3-way wiring.
Timer can be used for incandescent, halogen and CFL with minimum wattage requirement.
Since Aube timers have internal battery, they cannot be exposed to freezing temperatures or high temperatures.
Sep 28, 2011 | Aube Technologies Aube 7-Day Programmable...
We have a fan 60 minute push button timer we purchased and installed with a 3-wire system. WE need to purchase another one but they all have 4 wires now. Where can we purchase a 3-wire one.
It sounds like you have mechanical push-button type timer.
I need more information to avoid guessing which timer is best for your situation.
I'm not sure what a 3-wire system is?
Add a comment
1) How many switches control same fan
2) What color wires inside box.
Is this
3) low-horsepower bathroom fan?
4) other fan, for example: higher horsepower attic fan, 3/4 horsepower industrial kitchen fan, or 1-horsepower whole house fan?
5) Is this your home or is fan for continual commercial use?
6) Is this a countdown timer that turns fan OFF automatically after 60 minutes?
7) Or what kind of timer are you looking for.
Open following link for list of home-use countdown timers and horsepower ratings of countdown timers.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Spring-wound timers do not require extra Neutral wire, and can control 1 HP whole-house fan.
The push-button timers each require Neutral wire to run electronics inside timer, and they range from 1/6 HP to 3/4 HP which will work for any bathroom fan.
If you cannot give required information for more free help, then request fixya interactive answer and pay fixya expert to ask same questions while expert supplies you with immediate information.
Apr 06, 2011 | Woods 60 Minute Decorator Wall Timer...
I need help hooking up my bathroom fan and light i have three wires going to the bathroom fan and light white black and ground i want a swith to turn off the bathroom light one to run the light to the fan...
Right now a single switch turns on both light and fan.
You want to put in a double switch to control light and fan separately.
But the problem is there is not a separate wire to each the light and fan.
You need a separate wire to each, but the circuit wasn't wired that way.
Usually when the circuit is wired for separate control, there is a red wire that also goes to ceiling box.
Unless you run another wire to the ceiling box, it won't be possible to control light and fan separately.
Electrician can do this pretty easily if there is attic space above bathroom.
Oct 17, 2010 | Broan-NuTone Broan 68W White Decorator...
Our switch for the ceiling fan burned out today. Instead of getting the same type of switch (rotary knob with push on/off) I bought a Pass & Seymour combination toggle switch (dual on/off toggle...
The wire to the ceiling fan are meant to send voltage to the fixture only and are not usually wired to control both the light and the fan independently. In order to do that, you may have to pull another set of wires to the switch box and then connect them to the light circuit in the box where the fan is. In regards to the other wiring that you mentioned, it makes no sense that the wires go to the stove fan and the bathroom fan unless those wires are source wires that carry the incoming voltage.
Mar 17, 2017 | Pass & Seymour #690IGCC6 15A Ivory DPLX...
I am attempting to replace an old bathroom exhaust fan with a Broan 680 fan/light. I am having a problem with the wiring. There are 2 wall switches for the light and fan. The existing wiring has red,...
The red and the black are the hot wires. One will be the fan and one is the light. The white is the 'common' for both fan and light.
It sounds like the new fixture has got one hot for both the light and fan, they will both run all the time from one switch. This is the blue wire. Hook it to the red or the black, which ever one comes from the switch you want to control it. Hook the white to the white on the new fixture.
The green is just a ground. hook it to the new fixture green or ground terminal. Cap or the black or the red that you don't use. It won't be need for the new one. The switch that it comes from will not control anything now.
Jul 25, 2009 | Broan-NuTone FAN CONTROL SWITCH
Bathroom Ventilation Fan Motor Failures
I'm guessing that water isn't splashing up on this fan's motor, so the moisture that is causing the rust must be water vapor. The exact same water vapor that the fan is supposed to be removing. I have two suggestions before replacing the entire fan. One is to make sure that the ducting that carries the moist air out of the bathroom (and preferably out of the house altogether) is free of obstructions and that the fan can actually do it's job. Second is to actually run the fan, and run it a lot longer than you probably are right now. If it is running while you are in the shower and then you turn it off after you leave the bathroom, it can't possibly be removing that moisture. I'd invest in a countdown type timer and replace the existing switch with that. Set that thing for 30 or 60 minutes when you get in the shower and let it turn it off automatically.
Jan 28, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Aube Technologies Aube 7-Day Programmable 40-500w Light Timer Switch  Logo
397 people viewed this question
Top Aube Technologies Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you an Aube Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
