Question about HP Officejet 5610 All-In-One InkJet Printer
Hp5610 all-in-one HP5600 print cartridge- error- message1. after this message, the computer annouces: the problem is in the tri color cartridge on the right. (the tricolor hp22 is in fact on the left,( when I look at them). I have put a new hp22 the error message stays. I am disconnecting the power and the usb cable. It doesn't helpalso none of the "copy", "fax" or "scan" tabs is lit on.
  • 34 Answers
See it this site your problem solved
http://cluetechnologies.com/index.php?topic=688.0
Posted on Jul 03, 2010
INkCartrige error 50c. Will not print. Display this note each time I try to make copy or print from computer.
Hi there
You should always mention the printer model as well as what operating system you use.
This is what i found on LEXMARK's website about your error, and it seems you have one or 2 faulty cartridges, or you are using compatible cartridges instead of Lexmark Originals:
Problem Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Hope it helps
Andre
Sep 08, 2011 | Lexmark Office Equipment & Supplies
Insert the correct CD
Windows Users:
a Insert the gray HP All-in-
One Macintosh CD.
b Continue to the next page.
a Insert the green HP All-in-One
Windows CD.
b Follow the onscreen
instructions to install the
software.
c On the Connection Type
screen, make sure to select
directly to this computer .
Note : If the startup screen does not appear after you
insert the CD, double-click My Computer , doubleclick
the CD-ROM icon, and then double-click
setup.exe .
Jul 01, 2010 | HP Officejet 5610 All-In-One InkJet...
Cartridge Error 50C consult user guide. I
Cartridge Error
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Cartridge Error
Aug 13, 2009 | Dell A940 All-In-One InkJet Printer
Reoccuring align page error message
Hello sir; Wen you alginedthe you have to pick up the most clear letter then press resume if you don't pick up the number or letter and press resume , he message will come back again.
Aug 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Error 50 c
  1. Power off your printer.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Hope this helps.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
Have put in a new colour cartridge but the note on the printer comes up error 50C
Cartridge Error 50C
Cartridge Error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
LEXMARK X5150 CARTRIDGE ERROR
Try this --
Cartridge Error 50C
Cartridge Error
Nov 18, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP5600
You would need to go to your control panel, then printers, then right click on the HP5610 and then properties. Once there, you would need to look for the color setup screen. You should be able to choose something similar to: "print colors in black & white only". That is the only thing you can possibly change to force black & white printing. However, not every printer has this feature.
Jun 20, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
258 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
