Question about Mitsubishi WS-65869 65" Rear Projection Television
Blinking green light does not stop, tried to reset it but didn't work, any ideas?
  • Mitsubishi Master
  • 8,617 Answers
Failed DM Caps. You can get the WS55859 DM repair kit from www.tvrepairworld.com which also works for your model. The kit contains the caps and the CD with instructions.
Posted on Jul 03, 2010
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
Mitsubishi hdtv
NOT A GOOD IDEA AT ALL!
You likely now have one of two things happening:
1. Green power light constantly blinks and will not stop(should blink for 70 seconds and go out).
2. Green power light comes on and a few seconds later goes off.
Which do you have?
May 17, 2012 | Mitsubishi Televison & Video
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Canon mx310 wase ink full. Any ideas how to reset
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 13, 2009 | Office Equipment & Supplies
I refilled the color cartridge. The light that indicates lack of ink didn?t stop blinking. After a couple of prints, the second light for black ink also started blinking and now the printer doesn?t print...
You can try to press & hold the stop/reset button for 3-5 seconds.
If this still do not clear.
Again try to press & hold the stop/reset button for 3-5 seconds
If the stop/reset button does not work
You may try pressing the color button
Mar 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Nov 09, 2007 | Televison & Video
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
122 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
