Question about KitchenAid Dishwashers
Clean light keeps blinking and washer will not function. Cancel runs the pump for 2 minute, but the blinking light keeps going with no functions working.
  • 23 Answers
If the clean light is blinking that mean you dishwasher is having a heater issue. it is an error code. either your control board is bad or the heater or the ntc therm. if you take the bottom panel off you will see or should see a tech sheet that will tell you how to clear the error code or this website will help you. just enter your model number http://servicematters.com/docs/wiring/wiring_main.htm
Posted on Jul 03, 2010
Blinking cancel light, that won't cancel out, and won't allow other functions to be started.
While the door is closed, try pressing and holding the cancel button for about 10 seconds to see if it will clear.
Mar 31, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
How to clean ink absorber full on Canon i70 printer
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. Do not release the buttons.
2) While holding the Power button, release the Resume/Cancel button. Do not release the Power button.
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange. During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. After the function is selected, press the Power button. The LED lights in green, and the selected function is performed. When the operation completes, the printer returns to the menu selection mode automatically.
Mar 04, 2011 | Canon i 70 InkJet Printer
Washer will not drain have a F02 code. I have cleaned the fiter ahead of the pump, still having same problem
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Also keep in mine during winter time drains can freeze or slow way down
Dec 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check the electrical connections at the pump and make sure the pump is running.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
How to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My kenmore dishwasher, model 15822, just stopped working. The quick rinse light is blinking. The only other buttons that work are the pots & pans light which blinks when pushed, and the cancel button...
These are known to develop sticky switch contact pads. They stick in the contacted position and stifle the panel. Sometimes heat can be applied with a hair dryer to release them and make the unit function again. This is more than likely a temporary fix. New panels are available for about $165 to $200.
Jul 16, 2009 | Kenmore Dishwashers
The clean button keeps blinking, will not go off and i cant restart to wash. i hit the heat dry button for six seconds and it was unlocked but i cant get the washer to restart.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Feb 21, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Blinking clean light
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Ink Absorber Replacement for Canon i70 Printer
Not easy for most people to replace or clean ink pads, but this will reset
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
(Do not release the Power button.)
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Jul 05, 2008 | Canon BubbleJet i70 InkJet Photo Printer
Dishwashers Logo
178 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
