Question about Sewing Machines
Singer 4166 has it's Red and Green lights reversed. When the pressure foot is disengaged, that is when the green light is on and the machine will work (this is wrong). When the pressure foot is down the light is RED which means the machine will NOT run. This is the opposite of how it was when we got the machine - somehow the positions got switched and therefore the machine cannot sew.
  • 980 Answers
It sounds like reversed polarity and it is best to have it tested before you do any major damage
Posted on Jul 05, 2010
I have singer 4166 and it is all threaded and looks ready to but the red light won,t let me sew , what is wrong???
The red light usually signifies that the machine is not ready to sew because some function has not been turn off or has not been activated, the machine is not threaded correctly, or a myriad of other explanations.
Refer to the troubleshooting page (33) in the manual.
Singer 4166 Instruction Book Helpful Hints
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct and the needle has been installed facing the correct direction.
May 27, 2017 | Singer Sewing Machines
Singer 4166 suddenly started sewing only in reverse even when forward mode checked
open the top of the sewing machine. Then press the button or lever that changes the forward reverse mode. You may find that something got stuck there where it should effect the machine part. May a drop of oil on that spot can help?
Jan 11, 2014 | Singer 4166 Sewing Machine
I have error C7 on singer one plus and it wont sew at all?
I was getting a C7 error on my Singer Heritage sewing machine every time I pushed the pressure foot. I decided to see if the reverse sewing button would work and it did. Then I pushed the pressure foot to sew again and it worked. Hope this helps someone else.
Jan 27, 2013 | Singer Sewing Machines
RED LIGHT
here is a free manual for the sewing machine, see if the
information about the start button is in the manual, just click on the
link
http://www.singerco.com/uploads/download/1289_4166-e_f_s-complete.pdf
Nov 13, 2012 | Singer 4166 Sewing Machine
Tutorial for installing bobbin case for singer/4166 machine
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number---4166
Click search
Feb 27, 2012 | Singer 4166 Sewing Machine
Singer futura ce-100 wont start
Do you still have the embroidery arm attached? If you do, the sewing function of the machine won't work.
Mar 24, 2010 | Singer CE-100 Futura Computerized Sewing...
Red light comes on when pressure foot is down
Is your bobin winder thing on top pushed to the left? If it is pushed to the right - the machine will not allow you to start sewing.
Jan 04, 2009 | Singer 5050 Mechanical Sewing Machine
Beeping
I have had the same problem with my machine as well. have you tryed, keeping it hooked to your computer while sewing, even if you are not using your embroidery unit it still needs to be hooked up, that seems to have helped some with the beeping.
Feb 10, 2007 | Singer CE-100 Futura Computerized Sewing...
The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Oct 27, 2006 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
191 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
