Question about Nikon D5000 Digital Camera
Every time I power up my D5000, and press the shutter button half way (to auto-focus) the image in the viewfinder shakes, and after a few seconds the image shifts slightly and something internal seems to lock into place. After this, all functions are normal, but this issue is annoying, and obviously not right. Any ideas?
  • siggynine Jul 03, 2010
    Thanks for the tip, I'll definetely give it a try before having it professionally looked at.
  • 3,083 Answers
Inside the lens assembly, is a circular, edge-geared focusing lens, with electromagnets on it. It has to be able to spin freely to focus, and focuses with signals from the focusing system and cpu, etc. When any dust, lint, sand, etc. get inside, it can impede the lens from turning freely, or jam it. Your best shot at fixing this yourself is to get a can of compressed air ($4.00 at Walmat, and also cleans your computer vents too). Hold the camera with the lens facing down, and spray upward into the lens assembly with the lens extended. Hopefully, you'll free it up.
If this doesn't work, the camera will require a labor-intensive disassembly to fix it. If you can't live with it and have to get it fixed, get an estimate first. Often they just replace the whole lens assembly, and that can be expensive for parts, as well.
Hope it's just some lint- good luck!
Posted on Jul 03, 2010
My canon 70d does not zoom and focus automatically
My guess is the self timer was accidently turned on
Description
Using the Self-timer on the EOS REBEL T3i.
Solution
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
Attention:
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
NOTE:
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
Sep 02, 2017 | Canon Cameras
Hi, I have a Nikon d5000. Love it. Lately, when I put on the zoom lens--Nikon DX AF-S Nikkor 55-200mm 1:4-5 6G ED, and try to take a picture it will not let me. I have it on auto-focus, zoom out
Hi Anna,
In order for your Nikon to auto focus correctly, you need to have several things:
First - focus indicator. In your viewfinder, locate it on the bottom row of the status information bar; you should see a small, green circle in the left-most position. This will BLINK when you partially depress the shutter release (or back button focus - depending how you focus your D5000) whenever the subject is OUT of focus. It will switch to "STEADY ON" when the subject is IN focus. Please note that you will not be able to release the shutter any time it is blinking unless you make a change to the setting that will allow you to release the shutter when the camera is out of focus (not recommended).
Second - light. You must have enough light entering the camera for it to detect areas of different contrast on the selected focus point. If there is not enough light there is too little contrast for the camera to autofocus and no matter how close or how far (and everywhere between) the focus is set resulting in the camera "hunting" near and far to find it. The green circle will not stop blinking. Have you tried in a well lit room or outdoors in daylight?
Third - minimum focus distance. All lenses have a minimum focus distance. Acording to Nikon, yours is rated at 3.6' (1.1m) (see: http://www.nikonusa.com/en/Nikon-Products/Product/Camera-Lenses/AF-S-DX-VR-Zoom-Nikkor-55-200mm-f%252F4-5.6G-IF-ED.html for full specs on this lens). This means your subject needs to be at least 3.6' away to be able to focus on it - manually or aut0matically - it makes no difference. There are lenses that do "very close" focussing that are called "Macro" (but curiously Nikon branded versions of these lenses are called "Micro"), that are also telephoto lenses. Your lens is not a macro/micro type.
Lastly - operational equipment. It is possible that there is an issue with the D5000 camera body or lens (or even both). Try another lens to see it it works as expected. No other lens? Go to camera store with your camera and lens and "shop" for a new lens. Ask to try it out in the store and see if it it works. Maybe the counterperson will identify another issue with your set up.
I hope this helps & good luck!
Oct 05, 2014 | Nikon D5000 Digital Camera
So I have an EOS Rebel Xsi, and it has been working perfectly for the last couple of months. I turned it on and tried to take a picture in MF, but then a yellow light on the front starts flashing and...
Sounds like the self timer was accidently set.
Description
Solution
3. Press <Cross Keys> to select the desired self-timer, then press the <SET> button.
: 10-sec. self-timer (The remote control can also be used.)
: 2-sec. self-timer
: 10-sec. self-timer plus continuous shots. After selecting , press <Cross Keys> to set the number of multiple shots (2 to 10) to be taken with the self-timer.)
4. Look through the viewfinder, focus the subject, then press the shutter button completely.
Attention:
NOTE:
Sep 03, 2017 | Canon EOS Rebel XSi Digital Camera
I had my D5000 for a month now, recently i noticed something with my camera. looking though the viewfinder only, whenever i focus (half pressing the shutter button), the view from the viewfinder moves up,...
Welcome to the real world of photography, using the viewfinder is a whole new experience in the crating of fine photographs. Aside from this what you are actually seeing is the VR turning on and locking onto the target, you should actually feel this happening as well (if you are holding the camera correctly) What you are experiencing is normal. Thank you for the excellent description
Jan 18, 2011 | Nikon D5000 Digital Camera
Manual focusing on d5000
Most professional photographers use spot focussing...just the center dot. You focus on the subject...hold the shutter button half-way and recompose..press the rest of the way.
Jul 29, 2010 | Nikon D5000 Digital Camera
Unable to focus image in viewfinder
There is a little wheel nest to the viewfinder on the camera. It is called something like dioptric focus (forgive me I am going off of what I heard pronounced) and it allows you to manually set the focus to your eyesight. Just adjust the wheel while looking through the viewfinder and you should be set.
Aug 28, 2009 | Sony Cyber-shot DSC-H50 Digital Camera
Veiw finder(eye piece ) out of focus pictures are fine
Use the diopter adjustment to refocus the viewfinder to your eye.
Point the camera at a sign or something with writing on and half press the shutter button to focus then move the little adjuster at the top right of the viewfinder until the image in the veiwfinder is in focus
Jun 22, 2008 | Canon Rebel XT / EOS 350D Digital Camera
TROUBLESHOOTING c-750
There are a couple issues related to "slow" that I have with my C-750, and this is how I get around them.
One is the write speed to the xD card. This can prevent you from taking sequential pictures quickly, as the camera displays the current picture it is writing until it finishes. You can make the image of the current picture go away and use your viewfinder again, while the camera is writing the picture, by pressing the shutter button halfway and releasing it. Then you can see your subject in the viewfinder again!
Second is the delay between the time the shutter button is pressed and the time the shutter actually opens (when the camera actually takes the picture). This can be fixed by lining up your shot and pressing the shutter button halfway and holding it for a few seconds. This will give the camera time to adjust and lock focus, shutter speed, etc. There is a small green dot on the display below the battery indicator which will blink a few times when the button is pressed halfway, then remain on steady. When the green dot is steady, the camera is ready. Press the shutter button, and the camera should immediately take the picture.
Nov 12, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Focus Problem
I have the C740, which I believe works very similarly if not identically. Unless you have the camera in full time auto focus, I don't believe it actually focuses on the subject until you've pressed the shutter button half way. Until then, the subject may look in focus in the viewfinder, but is not. When you fully depress the shutter in one motion (rather than pressing half way first), the camera will attempt to focus before it takes the shot. If you are not careful about camera movement, you may inadvertently be focusing on something other than what you intended. My camera (and it seems all digicams) has trouble focusing in low light, so you definitely want to use the half press in such situations. Even then, I don't always get the focus correct. Thank the digital Gods for instant feedback! Personally, I almost always use the half press method. To get the 740 in manual focus, you hold the "OK" button down until you see the viewfinder display a focusing scale. It takes a second or so. You should also see "MF" and "AF" designations in the lower left corner of the viewfinder when the scale displays. Use the left and right arrows to select the focus mode you want (i.e. MF or AF), then use the up and down arrows to adjust the focus distance. You'll notice that the area you are focusing on is enlarged when you use the up and down arrows.
Sep 13, 2005 | Olympus Camedia C-750 Ultra Zoom Digital...
Nikon D5000 Digital Camera Logo
110 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
