Hello my is David a have a problem with my kenmore elite oasis 27062 when i start off to wash it rinse the water to cloth then it lock it self but when enter the spinning phrase it stop it display a error fl code i what to know what the problem to contact the manufacturer about this problem and get it fix
  • 23 Answers
The error code is an F1 . your washer is made by whirlpool and for them they had a recall for any washer that had that issue. what you will need is a new main control board and wire harness. here is the rework page whirlpool gave all of the service companies. http://servicematters.com/docs/doc_main.htm hope this helps. they should cover the cost of repair. one thing to check before you do all this is with no clothes in the washer spin the tub by hand just to make sure it spins freely. cause if clothes get between the inner and outer tub it can cause the F1 error code as well.
Posted on Jul 03, 2010
Bought in 2006 and quit working all together in 2007 then pulled it out today and the thing started working until the end of the wash cycle and wont come on at all again... it drained well but at the
Hello Kimberley,
It appears that a part of your question is cut off so i may be off base here but what i am reading is that your washer will go through the wash cycle and drain the wash water then just quit?? is that what is happeningIf yes that is whats going on i think what is happening is that after the wash cycle it fills with only COLD WATER for the rinse cycle and its not filling with the rinse water and just sits their until the rinse cycle water is filled and if its not getting cold water into the washer its not going to do anything If it is filling with cold water my apologies my bad for misinterpreting what the question reads and i ask ya to re-ask it.
GENE
Nov 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have the kenmore oasis he toploader. It keeps shutting off shortly after the water starts to fill and then it flashes ld. I am assuming that it is the lid lock. It will not start again. This washer...
i have the same one and have had the same proble last time i had someone out to fix it it was flashing ld as well it ended up having a pieice of clothing stuck betweeen the drum and the indise of the washer. its also flashed ud and it had a penny stuck in the water hose so i feel your pain. but you might want to check and see if there is something that some how got stuck on the out side of the drum hope this helps
Dec 27, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
The washer says f1 and wont rinse clothes so how can i reset it
washer fills but will not drain or spin!! should agitator spin seperatly from drum??? mine will not move!!
Jun 07, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore elite oasis top loader 27062
See the following Whirlpool / Kenmore service manual for the Whirlpool Cabrio washer. The Kenmore Oasis is basically the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Also see the Sears Parts site for your washer.
Enter the full (###.########) model number and you should see descriptions of the major components and parts lists.
May 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
So i put a load of clothes in my kenmore elite smartwasher and right after i start the washer the load stops and i get this message ''sud'', what does it mean?
IS IT AN OASIS? JUST RINSE THE SYSTEM OUT WITH WATER. YOU MIGHT BE USING THE WRONG DETERGENT. THOSE MACHINES REQUIRE "HE" DETERGENT.
Jan 14, 2010 | Kenmore Washing Machines
Kenmore Elite Oasis 27062, the lid lock broke
Simply attach both wires from the switch to jumper.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis HE quit during cycle
tell them you want another one.  It sounds like a bad start up capacitor on the motor.  Nothing you can do but wait and boil.
Apr 01, 2009 | Kenmore Oasis HE 27062 Top Load Washer
SPIN
Refer to manual; your filter could be blocked, or something could be clogged in the drain pipes. Plug off the wall & check the pipes, filter first.
Jun 06, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
