Question about Hi-Pro (HPP303W) 300-Watt Power Supply
Can you turn on an ATX power supply when not connected to a mother board?
    President:
  • 2,600 Answers
Yes, especially if you are testing the PSU connections with a tester. Just plug the PSU into a wall socket, it does not have to have its connections connected on the motherboard for it to be running.
Posted on Jul 03, 2010
Connect power supply to mother board
It helps to remove the motherboard to go on power supply connector, and then turns it back on the system board
Apr 18, 2013 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
There is any different between this mother board p/n 51884327 and p/n 51882625
Take the power supply to a retailer or computer shop in your local area. Pretty standard from what I have found out.
Bestec ATX 300 12Z Rev DDR Replacement Power Supply HP 5188 2625 Have a great day.
Jul 29, 2012 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
The fuse in my BR 300 ATX power supply has blown, what is its replacement part
You need to replace the fuse and dis connect the power supply to the mother board and turn nit back on and if the fuse blowns again then it is the power supply, that is bad, bou if it blowns only when connected to the mother board, the mother has a bad component on it.
Sep 16, 2011 | Computers & Internet
Not powering on my mother board
1st You check the power supply of computer. If the power supply is alright then check the connector.
  • It is properly connected on the motherboard.
  • Check the motherboard LED light on.
Mar 13, 2010 | Intel Desktop Board D945PVS - Mainboard -...
EMachine T6420 will only turn on to start the fans and then immediately turns back off - has Bestec ATX-300-12E power supply - do you think that's the problem
These computers have had problems with the mother board. I had one the same problem, and I did research on the INternet. Best advice.... find a replacement board which will fit this box. Then you will have to re-install the operating system with the cdrom. You may be able to repair the system.
More than likely the power supply is not the problem, but the board is suspect more than anything.
Sep 23, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Missing -5VDC and -12VDC
Could be.Some do some don't.Some have a circuit breaker. Take the cover off and check. Be careful though as some parts in the power supply can hold a pretty significant charge for quite a while even after the power supply is turned off.If there is no fuse or if you change the fuse and it blows again I would say a new power supply is in order. Good luck.
Dec 14, 2008 | Aspire (ATX-AS500W) (atx-as500w 12v) Power...
POWER SUPPLY FOR E-MACHINE
disconnect CDROM,DVDROM or any player for that matter and of course any other peripheral attached so as you remain with only monitor ,mother-board,hard disk connected to the power supply.if it doesn't work repair the faulty supply.
Aug 10, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
PSU problem
The total connection is two part if you disconnect 20*pin one part then four part is other part. when you connect 20 pin in mother board .the four pin connect anther port. then the power supply is on.
Jan 24, 2008 | Computers & Internet
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Hi-Pro (HPP303W) 300-Watt Power Supply Logo
141 people viewed this question
Top Hi-Pro Computers & Internet Experts
danielle yancer
danielle yancer
De ice
De ice
Are you a Hi-Pro Computer and Internet Expert? Answer questions, earn points and help others
