Question about Samsung LE32A457 32 in. LCD TV
Does Samsung LE32A457C1D Have PIP?
Does samsung LE32A457C1D have the capability of using PIP (Picture in picture)?
  • 92 Answers
SOURCE: not able to activate picture in picture
CHECK YOUR OWNERS MANUAL DEPENDING ON YOU MODEL AND THE TYPE OF CONNECTION(HDMIOR COMPONENT) IT MAY NOT BE AVAILIBLE WITH HI-DEF
Posted on Feb 22, 2008
SOURCE: PICTURE IN PICTURE (PIP)
Samsung say;
The feature only works on the AV/PC channels and not on a single tuner (digital or analogue) and only if your AV source (Sky Box/Freeview/Dvd ect.) is connected to the TV by way of the RGB or HDMI connections.
Good Luck
Posted on Feb 29, 2008
SOURCE: My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Posted on Jul 26, 2008
techbuster
  • 5081 Answers
SOURCE: SAMSUNG sp-p4231 sound, but no picture
try changing the display IC that would be the frequent cause of such problems
Posted on Jul 04, 2009
SOURCE: samsung 50" plasma tv with no picture but has sound.
I just had a similar issue with my 46" Samsung LCD and fixed it myself for $5.11! I realize we have different tvs, but I bet it is the same issue ... crapped out capacitors.
I researched the problem online and most places, like samsung's site, referred me to call a repairman and called for the whole control panel or power supply to be replaced for anywhere between $400-$1000. I was like ... "screw that" ... I refuse to put in a fautly part in the place of a faulty part. So I continued to research.
That's when I stumbled on youtube. There are many how to videos on how to tackle this daunting task. I read that the issue was more than likely faulty capacitors and there is a very easy way to tell if it is in fact the capacitors that are blown. instead of having a flat top, faulty capacitors are crowned or even ruptured! When I opened up my TV I saw 3 blown capacitors!
So I bought 3 new capacitors all with the same uf and higher volts ... I think all three of my capacitors were 1000 uf and 25 volts. I kept the uf the same (recommended) and raised the voltage to 35 volts. It doesn't mean more volts, it just means it COULD handle more volts if it had to (which was the problem those cheap Samsung bastards screwed up on). This is a very common problem with Samsung TVs.
Anyway, I have never soldered before, but I did it. I warmed up the solder on the bad capacitors and removed them them slid thenew ones in and soldered them in and popped everything back together ... and PRESTO .... the damn thing works better than ever!
3 capacitors= $5.11
1 solder gun and solder= about $18
fixing an incredibly intimidating TV by yourself= PRICELESS!
Seriously ... don't be afraid to F up ... check it out on youtube and other place and save yourself a bundle. Source(s): I just fixed my TV!!!!!!!!
Posted on Mar 17, 2011
Can I do picture in a picture?
Yes, you can. It has quite a capable PIP feature. See here for the user manual, p144-146 and further.
http://www.samsung.com/us/support/owners/product/UN60D6000SF
Dec 26, 2015 | Samsung UN60D6000 60 Inch 1080p Smart TV...
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
Oct 19, 2014 | Samsung New 55"" Class 54.6"" Diag. Led...
Samsung picture-in-picture feature
Keepm playing with your remote.I have a samsung with PIP The functions are not intuitive. Keep trying different commands and you may stumble upon a solution. Good Luck...
Dec 15, 2013 | Samsung Televison & Video
TV - Samsung LE32A457C1D White picture
This happen on all inputs including rear ones?
May 24, 2012 | Televison & Video
TURN OFF PIP SAMSUNG LN32D403E4D
If there is no buttlon on your remote that says PIP, then go into your user menu and get into the picture settings. Look for PIP options and turn them off.
May 02, 2012 | Samsung Televison & Video
I have a LN46A550 flatscreen...the picture is now only in the upper left hand part of the screen. It's basically 1/6 of the screen. I have tried to pull up the PIP function on the remote and it will not...
there should be a ratio button on the remote if not its deffinitly in the main menu click on 16/9 wide screen you seem to have the veiw secound channel working on you set but were is the big picture of the current show? anyhow try that and let me know how you went
merry christmas
Dec 22, 2010 | Samsung LN46A550 LCD TV
There is a black rectangle in the upper left hand corner. How do I get rid of it?
Check your PIP or POP (picture in picture or picture on picture settings)
usually by cycling the button PIP or POP will make it go away
good luck,
mrwindex
Nov 08, 2009 | Samsung LN-S4051D 40 in. LCD Television
I got my samsung tv and now has a black box over the picture HELP
It sounds like you have PIP (picture in picture) if you look at your samsund remote there should be a button saying PIP if you cannot find this my old Samsung telly used to have a slide down bit and it was there.
Give it a go, Hope this helps you out
Little Dish Fitter
Sep 02, 2009 | Televison & Video
Screen is black on my Samsung LCD TV
Press your input button for the correct input your using for cable or viewing regular channels.
Apr 14, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
No picture in picture regardless of any way I wire the tv HELP
Thank you for providing the exact brand and model number of your product.
What it is: PIP lets you watch a second program in a little window. More-elaborate versions can resize the window, move it around the screen, create still or multiple still images, or simply divide the screen into two same-size pictures, often called "picture-outside-picture" (POP).
What it isn't: PIP has a dirty little secret, though: If you use an external tuner such as a cable box or a satellite receiver, you can watch only one program at once. If some of your channels are unscrambled, you can watch those on the second window, and you can usually watch other sources such as VHS or DVD on it, as well. But even with two-tuner PIP, a single cable/satellite box will prevent you from watching two live scrambled channels simultaneously unless the box itself has two-tuner PIP.
Thank you for choosing FixYa!
Az.
Sep 20, 2008 | Samsung LNT3242H Television
Samsung LE32A457 32 in. LCD TV Logo
153 people viewed this question
Jerry Greenberg
Jerry Greenberg
