Question about Lexmark T650n Laser Printer
My T650n is leaking toner on pages I am printing. Using Lexmark branded recycled by Lexmark toer cartridges and about 2/3 are having this leaking problem. It is getting expensive. Is this a well know issue with these printers or cartridges?
  • 320 Answers
Toner cartridges do leak but not all of them. are you getting toner build up inside the printer cavity? can you see where it is leaking visually looking at the toner? toners usually leak around the drive gears. if your fuser is not running hot enough the printer will get incomplete fusing and the toner will build up on the fuser rollers then make blotches on the print jobs. take a flashlight and check the rollers on the fuser to see if they have any build up on them. when toners start to leak they usually leave toner on every page.
Posted on Jul 08, 2010
  • morckg Jul 08, 2010
    It is leaking and leaves toner on every page, the backs of pages and is visible on the roller in the toner cartridge. We are using Lexmark brand cartridges. It is about 2 of every 3 cartridges that we have this problem with. Crappy cartridges or crappy printer? Both are Lexmark.
  • norman steach Jul 11, 2010
    i would guess that lexmark third parties these toners out like alot of companies try a different brand there are lots of them that guarantee there cartridges. The printer isnt doing it.
I have a Lexmark C522 Color Laser printer, all cartridges are showing as ok, no error messages but printed pages have specks of magenta toner on them
It sounds as though you have a leaking toner cartridge. If you aren't using Lexmark brand toner, that is VERY likely.. nobody seems to be able to make a good compatible cartridge. Test by replacing it.
Feb 22, 2014 | Lexmark C522n Laser Printer
Tip
Laser printer has dark cast to entire page, prints ok.
You notice that the copies you print have a dark shadow across the entire page but otherwise seems to print fine.
You have a problem with the toner cartridge.
Toner copier/printers print by transfering toner to a drum using electrostatic electricity and depositing it on the paper. Once on the paper it is set using a heating element or fuser.
Over time the brush which contains the toner in the cartridge and the scraper which scrapes off any excess toner, or toner which is left on the drum, wears and allows extra toner to remain on the drum, which gives the dark shading I mentioned.
To compound the problem these days the cartridges are recycled and obviously at some point the scraper will wear out and you may be the unlucky person who purchased the unit. If that is the case I suggest returning the unit to the store of purchase and exchanging it or getting your money back. Most reputable stores do not have a problem doing this.
New cartridges would run out of toner prior to this problem developing. They have been designed to last slightly longer than the amount of toner which is in them. When recycled and refilled the problems start.
Recycled and refilled cartridges are not always marked as such so there is no way to tell if yours is a recycled unit.
Another problem these days is the drums are being made out of plastic instead of metal. They wear faster and die sooner and cannot be recycled successfully as often. Once they have a scratch they will never print a nice copy again.
If yours is plastic that is probably the problem. No matter which problem you have, worn scraper or plastic worn out toner cartridge, the solution is the same.
You need to purchase and install a new toner cartridge.
Thanks for using FixYa and for the great rating.
hardrocko
on Dec 09, 2010 | Office Equipment & Supplies
Lexmark T650 faded print on right side
try replacing the charge (top) roller. and make sure you place the transfer (bottom) roller correctly.
Sep 11, 2012 | Lexmark T650n Laser Printer
Lexmark n502x, nothing prints on page, toners are not very old
Please follow these steps to extend the life of the toner cartridge(s):
1 Remove the toner cartridge(s).
2 Firmly shake the cartridge(s) side-to-side and front-to-back several times to redistribute toner.
3 Reinsert the toner cartridge(s) and continue printing.
For further assistance, please contact Lexmark Technical Support
Aug 13, 2011 | Lexmark X502N All-In-One Laser Printer
I have a new toner cartridge but when I print the print is very light as if the cartridge is out of toner.
Please try to do the following steps
Remove the cartridge and shake it to redistribute the toner.
Using a dry cloth, wipe off any visible roller contamination inside the printer.
Reinsert the cartridge and print the internal test page.
For further assistance, please contact Lexmark Technical Support.
Feb 02, 2011 | Lexmark E321 Laser Printer
Will only print maybe one page of a 4 page document and sometimes wont print at all
Below are 3 possible solutions.
Unexpected page breaks occur
Cause Solution
Job has timed out.
Set the Print Timeout to a higher value:
Blank pages
Cause Solution
Toner is low.
Remove the toner cartridge from the printer. Shake the cartridge back and forth several times, and then reinstall it.
Install a new toner cartridge.
Toner cartridge is defective or empty.
Replace the toner cartridge.
Jobs do not print
Cause Solution
Printer is not ready to receive data.
Make sure Ready or Power Saver appears on the display before sending a job to print. Press to return the printer to the Ready state.
Specified output (exit) bin is full. Remove the stack of paper from the output (exit) bin, and then press .
Specified tray is empty. Load media in the tray.
Wrong printer software is installed.
Verify you are using the correct printer software with your printer.
If you are using a USB port, make sure you are running Windows 2000, Windows XP, Windows Server 2003, or Windows Vista and using Windows ME, Windows 2000, Windows XP, Windows Server 2003, or Windows Vista compatible printer
software.
Cause Solution
Internal print server is not set up properly or is not connected properly.
Verify that you have properly installed the print server and configured the printer for network printing. For more information about installing a network printer, click View User's Guide and Documentation on the Software and
Documentation CD. Copies of the printer software are also available on the Lexmark Web site at www.lexmark.com.
You are using the wrong USB or Ethernet cable, or the cable is not securely connected.
Make sure you are using a recommended cable.
Make sure the connection is secure.
For some reason Lexmark has not posted information for this model. If you need a manual you might try the C534 manual at: http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_C534&segment=SUPPORT&userlocale=EN_CA&frompage=null#2
Dec 10, 2010 | Lexmark C533DN InkJet Printer
When I print a test page or any other page on my hp laserjet 4 plus printer, the print is barely visible. The background on the page is very cloudy, as if the page was dipped in water. How can I resolve...
My first suspicion is the toner cartridge if it is a recycled cartridge. Did the problem exist prior to installing the new cartridge? If not check the print density. It should be set to 3. Turn off toner saver options.
Sep 19, 2009 | HP LaserJet 4 plus Printer
T632 lexmark getting dirt on printed pages
Hi Krimlakh,
Try replacing the toner cartridge first. Usually when this happens the waste hopper of the toner cartridge is full and start to leak on to the page.
Rgds
S88
Dec 18, 2008 | Lexmark T632 Laser Printer
Lexmark T650n Laser Printer Logo
620 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
