Question about Panasonic Panafax UF-490 Plain Paper Laser Fax
Error code 021 fuser unit fuser fan. To reset use service mode . What isservice mode
    President:
  • 3,085 Answers
Press
function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
wait for machine to reboot
Posted on Jul 03, 2010
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
enter the service mode
f9
enter
Apr 02, 2010 | Panasonic Workio DP-2000P Copier
Could you tell me what a Print Error 021 is and how to fix it - thanks
Hello, Karen.
From FixYa Support:
You can try a LBP Fuser Reset and Error Log Clear.
LBP Fuser reset:
Press-function-7-"monitor button 4 times slowly"- then the "start" * button. It should say service mode. push 7 then push 1 then start then push 2. 1 then start
LBP Error Log Clear:
Press-function-7-"monitor button 4 times slowly"- then the "start" * button. It should say service mode then press 6 then press 1 then 6 then you're done.
If that does not work, you need a new fuser and would need to get the printer serviced.
Hope this helps.
Dec 17, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
We are getting Error CODE 021 on our fax machine Panafax UF-560 and can't find the owners manual to fix it...can you help?
Error code 021 indicates a bad fuser but in some cases, the error can be reset. To attempt a reset, do the following:
  1. Remove the toner cartridge and close door back up.
  2. Power down the fax (switch is on the back side lower left) for 5-10 seconds.
  3. Power on the fax and see if the 021 code is gone.
  4. Re-insert toner cartridge
If this doesn't work, there's one other thing to try prior to calling a technician.
1. Push the function button
2. Push 7 on the key pad
3. Push Monitor button 4 times (it will only beep at you)
4. Push * on key pad
You should now see the service menu option
5. Push 7 on the key pad
6. Push "Set" button
7. Push down arrow button once
You should now see the fuser reset option
8. Push "Set" button
You will be prompted for 1 for Yes 2 for no
9. Push 1 on key pad.
You should receive confirmation that the reset is *COMPLETE*
10. Push Stop button until back to the main screen
11. Power down the fax
12. Wait 5-10 seconds.
13. Power on the fax
If this doesn't work, a service call will be needed to replace the fuser. I do hope this fixes your problem.
(reset information courtesy of Eliot at howtomendit.com)
Nov 12, 2009 | Panasonic Panafax UF-560 Plain Paper Laser...
Error code 021
Press
Function
7
monitor slowly 4 times
6
set
wait for the fax to initialize and come back to READY
Sep 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
I have a panosonic uf-4000 fax it keep reading error 021. It is not listed in the book. What does this code mean
021 is a fuser error, that can either be reset in service mode or i may need a part in the fuser. Best to call a local service rep.
Aug 12, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Panafax uf-895 faxes, won't print. Put a new toner in, gives message 021
Error 021 relates to the Fuser unit (the bit that gets hot inside).
It is not related to the toner, which is a bit strange, but try switch off/on first.
Failing that you may need to clear the error in service mode. To access this:
Press "Function", "7", "Monitor" four times, then "*".
The machine should be saying "Service Mode"
Then press "7"
The machine should say "LBP Parameter Set"
(not 100% about the next bit but it should be reasonably straightforward to follow the display on the machine)
You are looking for "LBP Fuser Reset"..I think it is this:
Press "2" for "LBP Fuser Reset"
Press "Start"
The machine may reboot at this point.
If this is done correctly and the error still remains, the Fuser Unit will need replacing.
Sorry to be a bit vague on the instructions..not worked on these for a few years :)
Jun 19, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Resetting lbp fuser
you need to do a lbp fuser reset and lbp error log clear
fuser reset
function- 7- monitor button 4 times slowly- then press * "start" button, should say service mode, then press 7- start- down arrow - start- then yes
log clear
function- 7- monitor button 4 times slowly- then press * "start" button, should say service mode, the press 6 - use the down arrow to get to lbp log clear.
if this does no work you need the fuser replaced
good luck
Oct 12, 2008 | Panasonic PanaFax UF-490 All-In-One Laser...
Panasonic uf885 error
Same here. I replaced the fuing unit but he error code 021 still is present.
Apr 01, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
We are not able to recive fax
this code means the fuser unit has gone over temperature, as a sftey feature the mc will have to have the fuser unit reset then if the reset (which is done through service mode) doesnt fix it then it may need a new thermostat or lamp.
Aug 26, 2006 | Panasonic Panafax UF-560 Plain Paper Laser...
Panasonic Panafax UF-490 Plain Paper Laser Fax Logo
259 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
