Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
The rubber belts I put on keeps burning when I first put it on, it gets so hot on the metal bar I hook it to, that it splits it it two..how do I fix this???
    Problem Solver:
Sounds like the beater bar is clogged with something. Try removing it and cleaning it up, sometimes hair gets wrapped around it and puts it in such a bind that it will burn the belt.
Posted on Jul 19, 2010
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
Replaces the belt on dirt devil dynamite pluse model put everything back together started it and it burt the new belt up that fast. I put it around the beater brush and the metal bar I thought it should go...
The metal bar you put it around if the bar itself does not spin it is going to burn the belt up. Every thing that the belt is supposed to go around has to turn or the belt will rub on the piece not moving and brake.
Mar 18, 2011 | Vacuums
Occasionally when vacuuming the carpet there is a burning smell from the vacuum that I can't figure out where it's coming from. The base of the vacuum also gets hot. Should the vacuum be serviced? Is...
It is the belt in the beater bar.
Turn over the vacuum and remove the screws in the bottom of beater bar and split open the casing
The belt is either worn and slipping or pulleys are wrapped with debris causing the smell
Please let me know if this helps
Jan 20, 2011 | Vacuums
I keep replacing the belt and keeps melting and breaks. what do i need to do? everything else is working, the little piece of metal that hooks on the belt gets too hot and melt the belt
i think your talking about the motor spindel,,(the little metal bit?) if the motor is that hot its going to burn out soon, check that the brush is free to turn if its tight free it off its full of grit or fluff also check that the motor turns freely
Dec 02, 2010 | Dirt Devil M084600 Dynamite Bagless...
Belt is on roller. Not sure how and how to reattach
When you put the beater bar back in have the belt hook in the normal operating position. Hold the whole beater bar housing upside down and turn the hook. It will grab the belt. Once it does, keep on turning. It will get tough to do, but turn it until you can't go anymore. Then put it all back together!
Oct 29, 2010 | Kirby G5 Bagged Upright Vacuum
Vacuum Belt keep breaking
When your first belt burnt, the burnt plastics goes into the roller ends and then it dries off causing your roller to not turn or put more pressure on your belt. Until you clean that you will continue burning your belts soon after you put them in. You need to add a little bit of WD40 or any other type of lubricant after you remove the tar from the roller.
Feb 26, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
My enviro vac is being stubborn
First , spin the brush roll by hand and see if it spins freely. Then remove it.
CLEAN OUT ANY HAIR OR THREAD UNDER THE CAPS Inspect the end caps , if one is melted you will need to replace the cap if available or the entire brush roll assembly.
The "metal piece" is the motor shaft. Clean any burned rubber of with fine wet dry sand paper, then install a fresh belt, using the brush for leverage to stretch the belt into place. Rotate the brush again to be sure it is not binding and that the belt is not pinched anywhere.
Buy 2 belts and keep your spare inside the hood of the vac.
Sep 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
My Oreck Vacuum cleaner keeps burning up belts. I
I am having the same trouble. I bought the vacuum new in October 2007 when my wife and I purchased a newly constructed home. Since it is only two of us, she only has to vacuum once a month. I have taken it in three different times and get the same story. It needed a new belt. Mine has white smoke coming out of it and smells like burning rubber. I contacted Oreck and got no results. They refused to let me discuss this with Dave Oreck, stating that he nevers talks with customers! Gary Neeble
Jun 05, 2009 | Oreck XL2000 Bagged Upright Vacuum
Belt is hot to touch
If the belt is hot or you smell it burning then chances are it has stretched a little and is slipping on either the motor shaft or beater bar shaft. If you are sure the beater bar is not restricted from turning then I would just replace it. Try this.. With the power cord disconnected, open the vac head to gain access to the beater brush and belt.. then remove the belt.. place the beater bar back into its holder and see if it easily turns by hand.. if it is free to turn..then plug the vac in and turn it on for a few seconds.. you will see and hear the motor come on but you should NOT smell anything burning at that time. If you do.. you may have another issue with the motor or power cord or both.. if you don't smell anything burning, then disconnect the power and just replace the belt.... Good luck.
Sep 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
139 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
