Question about Toro Garden
I need the belt diagram for a toro groundsmaster 72 side discharge turf mower deck model number is 30721
  • 8,197 Answers
May I also get the serial # so I can get you the right belt diagram.
Posted on Jul 03, 2010
I have a 1990 toro wheel horse classic 312 8 lawn tractor, it has a 42 inch side discharge deck, What's the deck drive belt size of this mower, model 31-12K801, I have searched for hours
If the belt is in one piece, put a chalk mark on the back of the belt and measure the length by running a tape measure from one side of the mark all the way around the belt until the mark appears. Take that measurement, subtract an inch for stretch and that number is the number of the belt you need. If it's broken in two, not three, then simply measure the length of the belt.
May 28, 2016 | Garden
Got a new cub cadet cc 720 es when I engage the drive belts it makes a squeak/rattle noise from the front deck, took off the top and can not seems to pinpoint the source of the noise.
A lot of hydrostatic rotary mowers squeal when u engage the PTO (blades) even when properly maintained or even factory new ev like the toro groundsmaster which is top of the line in its style of mowers. At the shop at work we think it's due to a change in the angle of stress from the floating deck. Nothing to worry about. Just make sure that you completely drop the deck before you engage the blade drive.
Apr 16, 2015 | Cub Cadet Garden
Belt diagram install
seems like everyone does but no one knows there model number... darn
Aug 25, 2014 | Toro 3 Standard Blades For Wheel Horse 50"...
I need a diagram for toro deck 30753
Hi
I have located both the owners manual and a parts manual with breakdowns of all the components of your Toro 52" Groundsmaster mowing deck.
Both can be downloaded from Toro directly at the following link;
Toro 52" side discharge mower, Groundmaster 120 Toro Direct link.
I hope this helps you and if you have any further needs, please feel free to ask.
Jul 11, 2014 | Toro Garden
Where is the model number on the frame of a toro recycler lawn mower?
Toro model plates are white stickers with black lettering. On rear bagging models it is usually under the rear bag flap to the left of the discharge area. On side bag and commercial type units it is frequently on the underside of the plate that is just below where you hold the handle while mowing. On older recycler mowers it was on top of the left rear portion of the deck and usually fell off before the mower was very old.
Aug 25, 2010 | Toro Garden
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Groundsmaster 120 user manual
heres a link
https://lookup3.toro.com/request/request.cfm?lang=ca_en
you can download and print for free or purchase one from them....you will need your serial #
Apr 20, 2009 | Toro Lawn Mower With Toro Power Tools
Groundsmaster 72
Have a toro groundmaster 72 that the spline went out in the power drive adaptor. the part is not avaible from toro.21-2260
Aug 30, 2008 | Garden
Garden Logo
840 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
