Question about Kenmore 24 in. 16029 Built-in Dishwasher
Kenmore 665.16032402 wont run
All lights come on when pressed except normal wash. dishwasher drains when drain button pushed
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
  • e_wurzer Jul 03, 2010
    the reset code is not working. some of the buttons are responsive( all except normal wash and high temp wash) i did get it to run the diagnostic cycle once and it ran through a cycle then the problem remained.
  • Rylee Smith
    Rylee Smith Jul 03, 2010
    To start with check the door switch and try to clean the drain hose & pump, if everything appears to be fine then it is the control panel that should be replaced.
3 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: kenmore 665 dishwasher will not drain
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 08, 2009
guru_dev
  • 315 Answers
SOURCE: Kenmore Dishwasher won't drain
If you opened and closed the door and it started, that sounds like a bad, door switch in the console.
But you did hear a hum sound when it tryed to drain, it could be the drain solenoid, or the motor/pump assembly.
Take off the bottom access and look at the solenoid when it starts to drain, the piston in the solenoid should move freely, up and down with the white drain flapper that it connects to.
Also check for bad wiring connections at the power junction box where the power hooks up to it under the dishwasher, i have seen the wire nuts either come loose or burn off due to loose connections.
Posted on Jul 02, 2009
Kenmore dishwasher blinking E2F2
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Then you have to wait 2 minutes while your Kenmore dishwasher runs its diagnostic test.
Then press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop any lights from blinking.
Jan 29, 2015 | Kenmore Dishwashers
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
Refresh control panel
Instructions
    • 1
    • 2
    • 3
    • 4
      Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
      Hope this will be of help to you
      Have an awesome day
Feb 08, 2012 | Kenmore Dishwashers
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Good luck.
Jul 14, 2010 | Microwave Ovens
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Nov 09, 2008 | Kenmore 15899 Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Kenmore 24 in. 16029 Built-in Dishwasher Logo
230 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
