Question about Toshiba 50HP82 50 in. Plasma Television
Is there a module to replace for 50" plasma Toshiba that only says "now booting"? What's the part called, if there is?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. A plasma TV is a very hard working device. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems in plasma TV's are caused by overheating problems. You’ll need to check the power supply board first for any swollen/bulged capacitors. As power supply board is the hardest working board in a plasma TV, it develops voltage to supply all components, high current + high voltage. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
  • crwesq Jul 03, 2010
    what is the power supply board called? In other words, is it like a "Z board" or anything like that? What I am looking for is a name so I can get on eBay and buy it.
  • Rylee Smith
    Rylee Smith Jul 03, 2010
    Thanks for accepting the solution. It is known as power supply board not the Z board thats a different part.
Toshiba libretto 50 ct wont boot
I haven't encountered multiple beeps on shutdown - but multiple beeps on startup is usually an indication of a memory issue. Frequently can be resolved by simply taking memory modules out and re-inserting them.
If problem continues, may need to replace memory chip. If more than one chip, put one in at a time and startup to see which chip is causing the problem.
Not sure, based on your description of the problem, if this is the issue - but certainly worth a try.
Best of Luck!
Jan 03, 2013 | Toshiba Libretto 50CT Notebook
Tip
Toshiba 50HP82 Manual Download
Download Toshiba 50HP82 Plasma TV Manual
Would you like to review the features of the Toshiba 50HP82 Plasma TV ?
Have you lost your Toshiba 50HP82 Plasma TV Owners Manual?
Would you like a digital, searchable, pdf version of the Toshiba 50HP82 Plasma TV Users Guide?
Follow this link (& click FREE) to download a pdf version of the Toshiba 50HP82 Plasma TV documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Toshiba 50HP82 50 in. Plasma Television
How much would it cost to replace the panel for the 50" toshiba plasma tv
More than it does to replace the complete tv, sorry.
It's the single most expensive part of the entire tv. When you buy the tv you're effectively getting the screen itself at a volume discount with the casing and electronics thrown in for free.
May 20, 2010 | Toshiba 50HP66 50 in. Plasma Television
50" Toshiba Plasma screen is flashing with flickering sound
www.tacp.toshiba.com/tacpassets-images/.../42hp66_om_e.pdf
http://www.fixdevice.com/smanuals/file/31149.html
Above, download these Service manuals, it will show you how to troubleshoot, and identify what board to repair change.
May 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
My 50" Toshiba 50HP66 says "Please wait, thank you for your patience" and will not allow me to access the menu or Video inputs. Any ideas of what is wrong? Thanks
It sounds like the boot process is stuck. The digital board would be the board to replace since that is the main controller for the set. The part number for your model is 72784100. Please take a moment to rate my answer. Thanks....
Nov 24, 2009 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Red light flashing. TV wont start.
Bypass the SEINE module if you know how. If you use off air HD you will have to get a new module.
Sep 26, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
TOSHIBA 50HP66 PLASMA TV
I'm do not think they will recall a product if it is not a fire hazzard.
Have you try calling them and ask them if they could help you?
The assembly that failed the most is the Ysus, something that you can be able to replace yourself by swapping boards.
Good Luck.
Apr 28, 2008 | Toshiba 50HP66 50 in. Plasma Television
Toshiba 50HP82 50 in. Plasma Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
