Question about Olympus Camedia C-4000 Zoom Digital Camera
Error Message The problem with the camera is it is saying "card cover open" even though it is clearly closed. This is in all modes of operation ie, can't take or download pictures. Can you provide us with a solution?
    Sergeant:
    Champion:
  • 333 Answers
There is usually a small tongue on the card cover that engages either a switch or some other device to detect if the cover is open.
Check that it is not broken or that the sensor is not damaged etc.
Hope this helps...
Posted on Apr 17, 2008
When I switch on my camera (sony rx100) the screen says usb mode connecting even though there is no usb cable attached. The message stays on the screen and the camera cannot be be used to take a pictu
if you can get to the menu on the camera see if there is an operations menu that says to disconnect the usb or to close the usb. It might just be on and not closed.
Apr 11, 2014 | Sony Cyber-shot DSC-RX100 Digital Camera...
Canon Si5 Lens Error message. Have tried suggestions on line
Welcome to FixYa.
There where wo reasons why do you receive a "lens error".
1. CF card slot cover or battery cover opened with camera on
2 . CF card slot cover or battery cover opened while camera was recording to CF card
In this case you have to ensure that CF card cover and battery cover is closed while camera is turn on.
You also need to be careful not to block the camera lens when turning on. Lens will have issues while retracting if your hands or even small thing that will block the lens to retrack while in motion of turning on.
Thank you for using FixYa.
Apr 08, 2011 | Cameras
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Card cover open error message
Hi!
You need to make sure that the memory card is correctly installed on the camera and that its door lock is closed.
Sep 05, 2009 | Olympus Stylus Verve / ?-mini Digital...
Every time i turn on the camera it say card-cover open
clean the seal around the door... else it is repair
olympusamerica.com/repair
Jan 20, 2009 | Olympus FE-310 Digital Camera
My screen keep showing the Card Cover Open Error even though the cover is closed. What can i do It says "Card Over Open" when it is closed
The card door sensor is either damaged, failing or gone completely. You can take camera apart, (7 screws I think) take the back off. Sensor is at the back of camera near the battery door. If sensor is missing, you will see 2 spots on the electronics board where it was connected. Carefully melt solder so that those two points are connected. If sensor is still in place it's probably damaged. Carefully remove sensor using small snips or something like that, with out damaging anything around sensor. Then solder 2 points together. Good Luck
Apr 09, 2008 | Olympus FE-190 Digital Camera
Error message: battery cover open. This message appears in the window and will not let me operate camera until problem is resolved. The cover is closed, but the message will not go away. I have re-set...
try closing the battery cover. if you do not know what that is, it is where the sd card and the battery are held. the cover for that is the battery cover. if it is closed, and still not working, make sure its closed all the way, if it is, take it to best buy or circut city or any other electronics store and ask them.
Dec 12, 2007 | Gateway DC-T50 Digital Camera
Coolpix s6 lens cover error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Aug 30, 2007 | Nikon COOLPIX S6 Digital Camera
Lens error
This may be related/helpful: My S3 in normal home use (no sand, wet or shock) just now displayed the ?Lens cover error? message, with cover only half open. Using a tooth pick I ?eased? it gently and it popped open, took a few trial pictures- fine, but would not fully close unless eased. Now will open and close slowly on own but error message blocks camera use. Then spotted cause - a loose thin sliver of silver trim from below flash around (there?s a gummy substance where it should be). When I first saw one end of this it was between the lens cover and the camera body as tho part of the mechanism, so I did not touch it. Now I know it?s jamming the lens cover operation is it OK to open the camera case to get it out? Questions: (a) Has anyone done this please? (b) Will this clear error message? Thanks.
Aug 21, 2007 | Nikon COOLPIX S6 Digital Camera
Olympus Camedia C-4000 Zoom Digital Camera Logo
119 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
