Question about Dryers
Kenmore Dryer 70 series. Recently moved. Clothes take 3 cycles to dry when vented to wall vent. Woreks fine when vented to room.
  • 47 Answers
Your wall vent is restricting your air flow somehow. Many times they get plugged with lint. When this happens it activates a thermal safety switch in the dryer and doesn't let it heat to the proper level.
Posted on Jul 03, 2010
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
My Kenmore dryer has heat, tumbles fine but I have to run 2 cycles to dry clothes and 3 - 4 cycles for towels. The vent line is new and I can feel damp warm air where it exits the vent line. It worked fine...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 15, 2011 | Kenmore 400 6943 Dryer
My kenmore 70 series dryer stops prematurely on a heat cycle. Suspect thermostat failure.
if it is still drying but not as good then the vent is restricted, disconnect the vent tube and run a load of clothes. if it works then you will need to clean the vent with a leaf blower or shop vacuum. Hope this helps Tim
Apr 16, 2011 | Dryers
My Kenmore series 70 dryer heats up but takes 3 times on 70 minutes to dry the clothes. After every 70 minute period when i check the clothes i open the dryer and it is like a steam room. It is getting...
Check your dryer venting for obstruction.  Take the vent hose off and run the machine,  If it works with the venting disconnected, It is between your wall and the outside of the house.  If it still has the same problem it is somewhere in the exhaust.  If the dryer can't circulate air, nothing will dry.
Dec 04, 2009 | Dishwashers
Doesn't dry well
it's not the dryer,it's something clogged with lint,the wall vent,dryer vent or lint trap or all 3,check them out-mike
Apr 25, 2009 | Kenmore 63012 Electric Dryer
Kenmore 70 series electric dryer. Clothes are
most common reason for this would be clogged vent...check all the way in and out!
Mar 16, 2009 | Dryers
My kenmore 70 series dryer will not dry clothes, but it does heat up inside and lets hot air out the dryer vent on the outside of the house.
make sure the dryer vent and the house vent are not clogged with lint this will slow down the drying process-mike
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore Gas Dryer-70 Series is condensating and doesn't heat up
reck vent starting behind dryer then to outside try drying a load with vent disconnected may get warm but will prove or disprove vent problem..water is from clothes and is recondenseing because there is no escape to outside
Jul 02, 2008 | Kenmore 63942 Dryer
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 | Dryers
Dryers Logo
104 people viewed this question
Top Dryers Experts
