Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer kicks circuit breaker
My MDE 5500AYW WHen on high heat kicks the circuit breaker off.
  • markalanb Jul 19, 2010
    Yes, it has been on the same breaker for two years wtih no issues.
  • Maytag Master
  • 3,053 Answers
Hello, Mark I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
Dryer kicks circuit breaker off after a few minutes running.
Hi gel937
Replace your thermostat, it is defective causing the dryer to overheat and kick the breaker
Mar 13, 2013 | iPhone Apps
Dryer will not heat up
You have to check and see if the Circuit breaker is not kicked. One throw of the Breaker makes the Motor run and the other gives it the heat. If that is not kicked then it is more than likely the Heating Element or one of the sensors attached to the Heating Element.
Jan 18, 2013 | Crosley Dryers
Dryer won't heat maytag neptune mde 5500 ayw
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My dryer stop heating and will not dyr bt the tub turns and still but out air
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 03, 2010 | Roper REX4634KQ Electric Dryer
IT RUNS BUT DOES NOT HEAT
Jul 02, 2010 | Roper Dryers
I have a samsung dryer dv328aer that stopped heating up.
Check the home’s circuit breaker and fuses. Electric dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Select a heat setting other than Air Fluff.
Clean the lint filter and exhaust duct.
Another common cause of a dryer failing to heat is a faulty element (Heating Element). You'll need to replace it.
Jun 21, 2010 | Samsung DV328AE Electric Dryer
Won't heat
Visually verify household fuse blown or a circuit breaker tripped.
The drum may be turning, but you may not have heat. Electric dryers use 2 household fuses or circuit breakers. Replace the fuse or reset the circuit breaker.
If the problem continues, call an electrician.
Jun 16, 2010 | Whirlpool LER5636P Electric Dryer
Dryer does not get hot
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}On my Maytag dryer it is accessible from the front of the dryer. 2 to 4 screws keep the front in place remove them and pull the front out and up from the bottom it may be hinged at the top. Now you should be able to see the element heater box.
If you feel confident here are the main things to do onchecking for no heat Electric Heating Dyrer
1 Check for 220 Volt at the heater entrance to the heaterbox (accessible from picking up the top on most dryer models).
If you have 220vthere the heater element is out.
2 If you don't have 220v on the terminals of the heater theproblem is in the controls.
The fuse link, thetimer contacts, the centrifugal switch on the motor, and the heater safetythermostat and operating thermostat(s), are all suspect and have to beeliminated 1 by 1.
Hope this helps.
With any luck all you need is a new element. Clean the ductout while replacing the heater if so because the main thing that causes heaterelement burn out is low air flow. A kinked Dryer vent hose, lint, and pluggedup fan circulator on the motor, or if yours has little holes in the insidecabinet where the air is taken to be heated and recirculated, these can getclogged with lint also and cause a problem are the 4 main causes of low airflow..
Hope this helps and please rate me accordingly Thank you andgood luck.
Mar 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Estate dryer kicks off circuit
you can check where the cord is connected to the drier did you use the cord off your old drier see if the cord is tight at the back of the drier and the center terminal of the cord should be on the center of the terminal block and why did you buy a new drier hold my rating till were done please
Jan 30, 2008 | Estate TEDX640JQ Electric Dryer
Kicks off circuit breaker
make sure your breaker is high in amps, at less 50 amp breaker
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
