Question about HP LaserJet 4L Printer
I have an old HP4L laser printer that runs on an LPT cable. Is there an adapter or different cable available to connect this printer via USB?
    Brigadier General:
  • 10,406 Answers
Use 932c deskjet laptop - plug doesn't fit
There is an adapter but it not work qualitatively.Better buy new usb or LPT cable and change it.
Nov 12, 2009 | HP DeskJet 932c InkJet Printer
Is there any way to convert an old printer cord to USB
I assume you mean the printer has the old style, wide "parallel" port i assume, and your PC uses usb.
There are adapter cables available to convert USB to parallel, but I think they are becoming harder to find. Check at your local Office supply/electronics store.
Apr 10, 2009 | Brother HL 1440 Laser Printer
Connecting printer
You can purchase an adapter "Parallel to USB" for printers to be used with printers.
http://accessories.us.dell.com/sna/productdetail.aspx?sku=A0489585&cs=04&c=us&l=en&dgc=SS&cid=30098&lid=674094
Hope this helps. Bud
Jan 09, 2009 | Xerox WorkCentre XD105F Laser Printer
Where to connect on computer
The printer will have one of two cables , either it is a USB cable , or an LPT cable
USB Cable Looks Like This:
The LPT Cable Looks Like This:
If it is the USB cable , it will connect to the back of your computer in a USB port, which looks like this:
It it is the LPT cable , it will connect to the back of your computer also:
Sep 29, 2008 | Lexmark Office Equipment & Supplies
Canon BJC 2000 question-1284 to usb
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Printer to PC cable
You can purchase an LPT to USB adapter, which connects old printers(parallel LPT) to new cards. Estimate cost is 30-40 us $. You could also get an LPT card for your PC, estimated 20-30 us.
Feb 21, 2006 | HP Color LaserJet 5500 Printer
HP LaserJet 4L Printer Logo
185 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
