Maytag MLG15PD Gas Commercial Dryer Logo
Posted on Jul 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sail switch open fault
The dryer says " sail switch open fault"
Marvin
Level 3:
Top Expert:
  • Maytag Master 85,242 Answers
  • Posted on Jul 03, 2010
Marvin
Maytag Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29046604
Points
266281
The sail switch is a safety device that turns of the dryer if insufficient airflow is detected out of the dryer vent. make sure the dryer vent is clear and air flow out of dryer vent is not obstructed in anyway.
1helpful
My dryer stopped, it indicates sail switch open fault. how do i fix the problem?
The sail switch is an air flow detection device inside the dryer. This is a problem a qualified electronics technician will need to address.
Mar 02, 2014 • Dryers
Wired a new 360 through Hum blew 3amp fuse. How to wire so it doesn't blow fuse. Have open EAC and EAC2.
Review figures 5, 6 and 7 on the installation instructions and compare with how you wired your installation.
The red wires are not used if you use a mechanical humidistat, (are used with electronic humidstat - supplies 24 volts and go to "hot", "commod" on humidstat). Yellow wired to "Hum" whether electronic or mechanical humidistat used.
If using sail switch or current sensing relay, cuts into one of the yellow wires. - One yellow goes directly to humidisat, then comes out of other side of humidistat & runs to to relay (or sail switch), and comes out of relay (or sail switch) and runs back to humidifier.
4helpful
Whats a sail switch
A sail switch is a Blower "on" proof switch. It's purpose is to prevent equipment such as air cleaners and/or humidifiers from energizing unless the blower is running. The sail switch literally has a sail that is put in the ductwork. When the blower starts, the airflow will push the sail so as to close a switch allowing accessory equipment to operate.
I hope you find this information to be very helpful to your moving forward. Let me know if you have any further questions, comments, or concerns.
Please leave a rating. :-)
2helpful
2answers
Sail switch fault
Step by step procedures with pics can be seen at any of these sites. (just copy and paste the link in your internet address bar under a new tab)
www.fowlercompanies.com/.../AD-20%20SL20%20CG20%20D20%20STI-8%20dryers%20Gen%20II.pdf
www.fowlercompanies.com/.../SL31%2050%2075%20Dryer%20HotSurfaceIgnitorGas.pdf
Apr 08, 2010 • Dryers
4helpful
2answers
No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
5helpful
4answers
Error code "43"?????
Thanks Marty for the info on the sail switch. We experience the same error code 43 problem. Seemed like the sail switch was stuck in the back position and didn't come forward when the fan started. So I bent a metal coat hanger and used it to pull the switch foward to "unstick" it. I tested the oven turning it on and off a few times and made sure that the switch moves forward with the blower fan starting when the oven was on, and moved back when the oven was turned off. Should be obvious, but make sure the blower is not running and the oven is turned off before you stick the wire hanger back there. A pretty quick and easy thing to try before calling the repairman.
1helpful
F64 code on lower oven of thermador model cm302
Go to:
http://www.assuredparts.com/ThermadorRangeFaultCodes.html
F64 Lower oven cooling fan air switch not detected Replace air switch,replace cooling fan,check connections, check P6 on PCB control display.
f64 fault code is an issue with the lower oven cooling fan motor and, or (air) sail switch
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
