Question about GE DBXR463EBWW Electric Dryer
GE Dryer Question
I have a similiar dryer to the GE DBXR463EBWW , it may be the same. I can only remember the last few letters of the model number. It makes a strange noise when it turns, almost like it is having trouble turning but the speed appears the same. It stopped turning all together so I unplugged it from the wall and when I did it blew the breaker. I inspected the wiring and plugged it back into the wall and it started working again but with the same noise so we have not ran it since.
Any ideas?
mitchwilliamson@yahoo.com
  • 943 Answers
Hi thanks for the question on the ge dryer the blower loosens off the motor shaft and then rubs on the front to check disconnect power open door a few screws on the inside of floor top remove screws lift top remove 2 screws on inside of front remove front set aside blower is on left see if the blower is too far forward if so loosen 3/8 nut push blower back tighten the nut good and tight re assemble and try te dryer thanks the appliance doc
Posted on Sep 27, 2008
GE dryer drum hits idler pulley during rotation.
The belt is most likely either the wrong size (too long) or the belt has stretched. A new belt of the correct size should solve this problem. Make sure you have the model number when you buy the belt. I recommend that you take the old belt with you and verify that the replacement is a little shorter.
Apr 25, 2010 | GE DBXR463EBWW Electric Dryer
Ge gas dryer starts hot but goes cold after a few mintues of running
more likely than not the gas coils that operate the gas valve have gone bad.. if it fires at all the safetys, etc are good..
if i had model number i could be more specific as to how to get to them and part #'s..
hope this helps,
best of luck,
ttfn
Oct 29, 2009 | GE DBXR463EBWW Electric Dryer
I need the part information for a new belt for this model GE dryer(DBXR463EBOWW)
The part number on a drive belt for the model you have listed is WE12M29. It can be purchased on line at pcappliancerepair.com for about $11. I hope this helps you.
Oct 28, 2009 | GE DBXR463EBWW Electric Dryer
We recently purchased a GE dryer and were told it is electric or gas operated, the dryer runs but is not heating up. i think it might be because it isnt getting enough electricitry, but i cant get the back...
If your dryer came with a regular grounded cord attached, it is a gas dryer, and you will have to hook up a gas line to the 3/8 pipe nipple at the lower left corner (when viewed from behind). The 4 prong power cord is only used for electric only models. If still unsure, post the model number from the sticker inside the door of the dryer.
Oct 04, 2009 | GE DBXR463EBWW Electric Dryer
Hi, my GE model DBXR463ED1WW dryer is LOUD!
Roaring could be an over firing burner or fan related. Squeak or rumbles are bearings. Is the noise all the time or only when the burner is on? Eric
Jun 20, 2009 | GE DBXR463EBWW Electric Dryer
Heat shuts off after a few minutes
Check Replace Thermostat. The Dryer Thinks Its Not Lighting Because The Thermostat Isn't Working.
The Dryer Has A Safety Mechanism So It Wont Flood Your Home With Gas. When The Thermostat Is Broken The Unit Doesn't Detect The Heat And Shuts Off The Gas.
If You Like You CV
Jan 09, 2009 | GE DBXR463EBWW Electric Dryer
Dryer do not start
IT'S YOUR DRYER MOTOR,IT'S SO WEAK IT WILL NOT TURN OVER,YOU MIGHT FIND A CHEAP ONE ON EBAY-MIKE
Dec 06, 2008 | GE DBXR463EBWW Electric Dryer
1-1/2 old dryer keeps stopping
could be a bad motor or timer contacts. can you hear a humming sound coming from the motor if you tried starting it again? if there is none, wait for about 5 mins and try starting it again, hear what happens?..
Feb 24, 2008 | GE DBXR463EBWW Electric Dryer
GE DBXR463EBWW Electric Dryer Logo
60 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
