Question about Dell Computers & Internet
Dell Dimension 5100c Model: DCCY will not boot.
Dell Dimension 5100c (DCCY) Model: DCCY
I have a Dell Dimension 5100c that just stopped working.
If I plug the power cord in the green light on the motherboard lights up. Which makes me believe the power supply is fine.
I have changed out the front USB1 audio & led panel that has the power switch on it with a new one and this did not help.
I've reseated the RAM.
I've disconnected all of the hardware.
I'm thinking it may be a motherboard issue, but my thought is the green light on the motherboard indicates that it too should be good. ???
Help is greatly appreciated.
Thanks.
  • Dell Master
  • 4,806 Answers
Is the power button a steady abmber light?
If so follow the instruction below>>>>
Remove the power cord from the back of the computer. Then open the side casing of the tower and unplug the 24 pin block connector from the motherboard. The 24 pin block connector looks like this >>>>>
Dell Dimension 5100c Model:  DCCY will not boot. - 0b6066f.jpg
Once removed press the on/off button on the computer to dispel and residual power from the motherboard.
Then connect the block connector again and put the side panel back on and then plug the power cord back in and try to boot the computer up.
If its still the same then the power supply inside the computer may need replacing.
Good luck.
Posted on Jul 03, 2010
May dell model DCCY
You didn't ask a question, but you can download the manual here... http://www.manualslib.com/manual/36845/Dell-Optiplex-Dccy.html
Jun 21, 2014 | Dell Computers & Internet
Cd and dvd not found in device manager and computer on dell series 5100c\
Hello, It sounds like you don't have the drivers for the cd players, pull the cd player out and find out what make and model it is. Then google the device and get the drivers for the operating system you have.
Dec 20, 2013 | Dell Dimension 5100C (D51CL1) PC Desktop
5100c wont power up and green LED next to power supply is blinking.
Hold the power button in for 10 seconds on the tower, then push it back- it sounds like your system is locked into standby/hibernation- holding the button forces a full shutdown. If that does not work, write down your express service code. If the system is still in warranty, you may need to contact Dell technical support to have your system troubleshot for No Post. If not, utilize support.dell.com to troubleshoot the No Post situation- often, the system will tell you which component failed, which saves you money as far as repair costs go!
Nov 04, 2010 | Dell Dimension 5100C (D51CL1) PC Desktop
On a dell dimension 3100c, i am getting the error when i boot up of Drive 1 not found, parallel ATA, PATA-0 (Pri ide master) When i press F1 the system boots up normally. My hard drive is SATO 0, and...
The DVD drive is having a problem. Ensure the Jumpers are set to Cable Select, and both the data and power cables are seated well
if the drive still doesn't work right, boot to BIOS, turn on caps lock, scroll Lock and num lock, press ALT +E then ALT+F then ALT+B and let the system reboot and re-detect the drives
If still no go, you can try a different drive and or a different cable
May 31, 2010 | Dell Dimension 5100C (D51CL1) PC Desktop
I get a blue screen error message ''c000021a unknown hard error'' after running CHKDSK as a result of receiving an initial blue screen error message ''The Type of file system is NTFS. The volume is...
Hi, Boot into Safe Mode by pressing F8 at bootup and choose
'Safe mode with command prompt'
At the command prompt type
C:\Windows\system32\restore\rstrui.exe
Hopefully System Restore will open so choose a Restore Point a few days ago.
Please rate my response!! Thanks, SF
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100c fan loud, is this normal?
fan is either dirty and needs cleaning or fan's ball bearing is damaged and needs replacement.
Apr 26, 2009 | Dell Dimension 5100C (D51CL1) PC Desktop
Computers & Internet Logo
930 people viewed this question
Alun Cox
