Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Need manual for husqvarna chain saw parts - Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
I am looking for a manual for a Husqvarna model 2768 chain saw
Posted on Mar 28, 2011
    President:
  • 2,220 Answers
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Jul 03, 2010
SOURCE: husqvarna chain saw oiler
Hi!
Oil pump mechanism is broken or the oil exit is clogged
Mark
Posted on Oct 24, 2008
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
steve_lima
  • 181 Answers
SOURCE: Pull cord on chain saw will not retract.
make sure the spring is going the right direction when pulld,put spring back in recoil housing carefully if you do it to quick it could spring back on you..... yes it hurts. after you have the spring back in the recoil housing take the rope off rope rotor.that's the piece that holds the rope.always replace to rope even if it looks good...feed new rope on rope rotor, first heat he ends of the rope so it will go in the holes easier.tie a hove hand knot in on end of rope.....put rope in rotor and pull knot thight,feed rope onto rotor until you have no more room for rope.... there should be a notch in rotor for rope to lay in....install rotor and screw tha hold rotor in place....have recoil handle handy....holding on to the rope spin the rotor two rotations....install handle......please be careful
Posted on Jan 09, 2009
rowdy45176
  • 2176 Answers
SOURCE: locate exploded drawing of poulan chain saw
I tried a couple locations and found a site that might help go to psep.biz and it will direct you to the blowup. It also indicated that it needed a type number so have that handy. If this doesn't help let me know and I will research further.
Posted on Jan 18, 2009
SOURCE: Chainsaw Service manual for Husqvarna in New Zealand
Free download on:
http://lawnandgarden.owneriq.net/ex/thread/view/idThread/278287
Posted on May 15, 2009
I need a piston & clyinder for a husqvarna chain saw spurios parts might suit.
There are plenty of pirate parts on the web, they are not always the best, but are always much cheaper than original parts.
Sep 06, 2011 | Husqvarna Chainsaw Piston Kit for 61...
How do I tighten the chain for model 136?
A link to a 2003 Husqvarna 136 follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2003/HOUS2003_O0301010.pdf
See pages 7 and 8 for chain adjustment installation/adjustment.
All Husqvarna saws may be found here:
HusqvarnaUSA.com
06 1500198
Lou
Sep 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to assemble the chain brake on a Husqvarna 137 chainsaw
A link to a Husqvarna "IPL, 137/ 137 e, (revised 2008-04) 2006-12, Chain Saw" follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601906.pdf
Page 1 displays the chain brake in good detail. The hand guard must be rotated aft to latch the brake band in the expanded position or it will not be possible to reinstall the cover. It requires a fair amount of force to latch and a vise (use wooden blocks on cover flats to protect the finish) or a large C-clamp to a work surface will probably be required.
HusqvarnaUSA.com (if the above is not your saw, IPL displays parts)
06 1500198
Lou
May 06, 2010 | Husqvarna Garden
Husqvarna 380s oil line and filter
Your saw?
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/03ab0a8df783c8e388256b3800145b74?OpenDocument
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
There are 4 380ses - listed. They are so old i ask you contact Husky to decode which IPL applies. Identify the parts you need and do an Internel search for "Husqvarna YourPartNumber" to verify part availability.
Husqvarna.com Contact Us
Good Luck. HTH
Lou
Feb 22, 2010 | Husqvarna Garden
Husqvarna 345 leaks (over uses)chain oil
An IPL (exploded parts list) for your saw can found here:
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
00198 = 198th unit produced by Husky that week
The manual and IPL list no way to change oiler output. Your manual (page 16) says
"If the chain lubrication system is still not working after
carrying out the above checks and associated measures
you should contact your servicing dealer." HTH
Lou
One question - are you using bar oil? It is thicker and stickier than most oils.
Oct 07, 2009 | Husqvarna Chain Saw 20" Bar
Chain oiler not working
Go to husqvarna.com then US the support then product manuals, look up both saws and see if the part no for each saw is same.
Apr 15, 2009 | Husqvarna Forest & Garden No.967012396 345...
Production year for Husqvarna Chain Saw
86 or 96 - 13th week - 6460th saw made that week
Lou.
Apr 13, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
471 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
