Question about Kenmore Refrigerators
Kenmore Elite refer 50594000 w/in-door water/ice water leak
Kenmore Elite 50594000 w/in-door water/ice leaking. Can't find manual. Leak appears to be in front underneath. Manufactured 08/2000.
SOURCE: Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Posted on Apr 04, 2007
  • 23 Answers
SOURCE: water leaking from bottom of refriderator
Is this a self defrost refrig. if it is then it might be doing that, which then you might want to look for the drain that is suppose to drain into this pan. It might be missing the pan try that, let us know thanks.
Posted on Dec 07, 2007
  • 1122 Answers
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Posted on May 31, 2008
huuum
  • 750 Answers
SOURCE: kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Posted on Sep 27, 2008
SOURCE: FF200EP Fridge Freezer - water
I had the same problem, the fridge would leak overnight (usually) I found with some more searching the answer..... try it at you own risk!
Here are 2 detailed answers depending on your circumstances/technical ability....Turn off fridge....
1. Defrost fridge...catch all the water
or
2. Work quickly....
Remove drawers, at the back of the fridge there is a panel with 5 phillips screws (note that there are long and short screws). Remove the screws and the panel. (if you chose the second option then this will be "frozen in place" so you will get crunching noise when you peel it away - so be careful when removing it). At the top of the panel is a connector that powers the fan, squeeze the 2 sides in to remove. This will allow the panel/ducting to be removed from the fridge. (If you chose option 2 you will now probably see a large lump of ice over the drain hole).
Remove ice or debris from drain hole, re-asssmble not forgetting to connect the fan again!!!) then repower the fridge following the instructions as you will get the alarms... the fridge cools and the warning lights dissapear.......24 hours on mine is OK!
Mal Function
Posted on Dec 28, 2008
We have a Kenmore Elite 795 fridge. It is constantly leaking water from the bottom right corner of the unit onto the floor. There always seems to be a build up of ice at the bottom of the unit.
Usually the result of CONDENSATION due to eithr bad door seals allowing air and moister in to condensate. or a plugged or clogged evaporator drain line which causes water to back up and freeze or leak out the lowest point the bottom?
Mar 19, 2015 | Kenmore Refrigerators
Leak from freezer into refridgerator, near the back.
You did not mention what Model and Make it is. That could change a fix.
Just a generic fix, assuming the unit its not too new, the first thing you want to do is turn the water off that is feeding your ice maker. Behind the refer on the wall. Be careful to not kink the water pipe pulling out and putting back the refer during your repair.
If stopping the leak into the refer was accomplished by turning off the water, now your confronted with how old is the refer and is it worth digging around and finding the actual leak. If the leak is in the wall of the refer (not the house wall), basically, just forget it, live with it and buy some ice trays. If you want the ice and it is really old, you may want to take this opportunity to replace the unit.
This would be my first assessment, not knowing age, make and model number. Sorry, wish I could be more helpful.
kindly,
Jim
Jan 16, 2014 | Kenmore Freezers
I have a Kenmore elite Model #795 7554 2501 MFg date 2005-01. The water container behind the left door is leaking I need a replacement. Can you help
in trying to locate this model # with sears data base it didn't come up. i don't know of any kenmore that has a water container behind the left door . left door being the freezer door .. the water container is located in the botttom of fresh food side in the back behind the crispers . if thers a leak in the freezer door i would think that it a water line that is carcked or come loose .. mm hope this helps .. pls reck your model # and in needed get back with me ..mm
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have kenmore 970c4006200 plastic tub water leak
Perhaps been hit by a coin..Try sealing with silicone, give it a good clean 1st the roughen it with sandpaper to give it a Key......It may of course be from the Door boot seal you need to check this and @ pump also just in case..Please leave feedback
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
Water in Leaking in the Freezer
Hi, this sounds like a problem with a blocked drain. For full instructions on clearing the blockage from my tips click HERE if you have any other questions please feel free to comment. Mike
Dec 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Bottom Refer Internal leak
Hi, look and make sure the inlet tube to the icemaker is inside the fill cup. Make sure there is no ice build up in the fill tube also.
I hope this helps some, please let me know if I can help further.
Thanks Vic
May 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite HE3 water is leaking out the front door
These are notorious for the door boot leaking. Look for any tears, rips, pinholes in the door boot. Also make sure the door is parallel with the machine. Most likely it's the boot. Parts about 100.00. Labor can run from 110-140 depending where you go.
Mar 16, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite - bottom Freezer - water leak from refrigerator
Found this solution on another site. http://davesgarden.com/community/forums/p.php?pid=6759829
Jul 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Oct 19, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
