Question about EliteGroup L7VMM2 Motherboard
New power supply does not work...is it the motherboard
New power source does not work store where i bought power pak says it may be the motherboard ...how do i know if the mother board in not operatable..also the supply is rated for higher then my original wattage could that have something to do with it
    President:
  • 1,768 Answers
If the mother board is not receiving proper voltage to power up it may be that the boards internal regulator has failed.
You stated that the power supply (new) is rated higher than that of the mother board this will not work because you are inputting more current that the board will handle and this can cause further damage.
I suggest purchasing another mother board with higher specifications if your cabinet will allow it .
Posted on Jul 03, 2010
    Scholar:
  • 94 Answers
Well there are two ways to to figure out which item is broken first you can hook up the power supply and test the pins in the plug with a voltage tester to see if it has power. I do not recommend this approach if you are unsure of what you are doing the voltage coming from a computer power supply is very dangerous. the second thing you could do is attach a different power supply to *********** board if ti works the mother board is good and it your power supply that is busted. Also make sure to check the back of the power supply and make sure it is set to 110 and 220 voltage because this can cause your power supply to not function correctly. It will be a little red switch on the back that says 110v on one side of it and 220v on the other.
I hope this helped.
Thank you,
Norse
Power supply Abit IP35-E Motherboard power supply
Hello here is the abit homepage:
http://abit.ws/page/en/download/download_driver_detail.php@pFILE_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=IP35-E&pSOCKET_TYPE=LGA775
This mainboard uses the ATX power supply, and a new power supply can be bought in a computer store, or online.
The price is about 100 dollars, for a good quality power supply.
You can take the case with you to the dealer, so you get the right one.
Good luck
Apr 01, 2013 | Computers & Internet
Good luck
Apr 01, 2013 | Abit IP35-E Motherboard
My PC power supply crashed, burnt resistors, Powerman IW-P250A3-1 20 pin plug to motherboard, bought new power source, but the old power source had a white cable to the 20 pin plug which was -5vdc 0.3amp....
For your system to boot up properly, you need an identical power supply for your system. Most likely the reason why your system won't boot up right now is because you purchased a different power supply and it is lacking something(which is the other pin).
Regards
Sep 14, 2011 | Computers & Internet
I just bought a new pc. It worked in the store. I also purchased a graphics card and power supply upgrade. I switched out the components exactly as they were. I now have no power. what might be cuasing...
either the graphic card is not compatible or the power supply that you changed is not fit for the motherboard....
check this
1 switch on the machine....if u can view / hear the fan on the power unit at the back of the PC running then the power unit is working.
2 do u get any msg or charecter on the screen when you power on the manchine ? if yes then the graphic card is the issue....
3 the cables inside the PC that you connected of the power supply are not properly joined in the MB
well at the last i will ask if the PC was new why did u make an upgrade....u could have bought a better PC with the extended features ??? well that's ur choice...!!!
ok then....
just put back the original power supply and original graphic card to c if it works now....
then let me know pls...
regards
Oct 15, 2010 | Computers & Internet
Computer was working fine. Turned it off and the next I went to use it the screen will not come on. I understand that there is a certain key that you press to get it back on but I don't know which one it...
When you press the ON button, do any lamps on the front of computer light up? Do you hear any fans start to spin?
Do you feel any air being blown out the back (source is the fan inside the power-supply) ?
If not, your computer's power-supply has failed.
Take your computer to a computer-store, and get them to sell you a replacement. Probably less than $50.
Hint: the smaller store that you take it to, the more-likely that the sale of the power-supply will _include_ "installation" of the new power-supply.
Aug 05, 2010 | Computers & Internet
Needing to plug new power source to motherboard, need the diagram format
the easyest way to do it is to open up the side panel of the computer rite down the info off the side of the power supply such as voltage and so on then go out and buy the same type then as you pull out a plug from the one in your computer put in the same plug from the one you bought and you should be rite, theres nothing that technical you need to no just disconnect it from the power and pull out the plugs its that easy
May 29, 2009 | E-Machines eMachines Desktop PC
A new Wii bought from the US was plugged into a 220 V power source. The Wii would not operate. How do we get it fixed. Am in Pampanga, Philippines
If you haven't already you might want to try buying a plug that is for the Wii from a local store. it should only cost a couplpe of dollars. The US power supply is only capable of using 120 volt power source. By buying a power supply from the local store it should not matter where the main system is from because the power supply regulates the input power down to the required power that is ment for the game console.
May 12, 2009 | Nintendo Wii Console
E-machines desktop PC will not power up at all
Power supply first. at least 450 watt.
If you need more let me know
Mark
Apr 11, 2009 | E-Machines eMachines Desktop PC
My motherboard can't turn on and me had changed power supply with new one.Can you help me how to check power on motherboard.Thank you. I bought a new case for my ATX motherboard. I installed the power...
the chances are that the power supply is not enough for the motherboard. or the main power connector has only 20 pins. the newer version of motherboards requier 24 pin power connector.
Mar 24, 2009 | Computers & Internet
EliteGroup L7VMM2 Motherboard Logo
145 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
