Question about Briggs & Stratton Garden
I have a sovereign ng464 and the body of the mower has rusted so badly it needs replaced. Any ideas on locating a replacement
  • 63 Answers
Depending on where you are in the world it can be more expencive to replace the deck than to buy a new machine
Posted on Jul 25, 2010
What to do if the body is rusting away on my yard works lawn mower 6.5HP
Your best bet is to look on craigslist for someone selling a mower similar to yours with a bad motor. Buy it cheap and swap motors.
New chassis are available through your local dealer also. You will need model and serial numbers from your chassis.
Sep 01, 2014 | Garden
Why Spark on Briggs and straiten motor?
Does it have a shutoff wire on the carburetor?
Use a meter to check the coil at the magneto - if that coil reads "open" (no continuity), then it's bad & needs replacement.
Jul 26, 2014 | Garden
The body of the lawn mower is starting to rust and when you try to turn the lawn mower by lefting the front with your handle it rips more. Is there any way you can replace the body of the lawn mower<
I keep my eyes open for a mower that is junk suich as one the motor is shot and make sure it's about the same type as the one your changing and there are four bolts that you take out of the mower base that holds the motor in place take them out and undo the cables and replace the new base. Some times the handles are interchangable as well.
Sep 17, 2013 | Briggs & Stratton Garden
Sovereign 35 classic white smoke
White smoke usually means there is water getting into the cylinder head. If your mower is not water cooled then there might be some water in the petrol. If the mower is water cooled then the cylinder head gasket has gone and needs replacing. Good Luck. George
Mar 29, 2013 | Garden
I have been told to coat the bottom of my new lawnmower with fiberglass coating to extend the life of the body- is this true, or even a good idea?
While it may extend the life it may also trap moisture and rust it out....also could be rough and catch the grass causing other issues...overall it probably is not a great idea...your mower will probably have something else go bad before the deck anyway...
heatman101
Sep 08, 2010 | Garden
I need a replacement wheel for a sovereign petrol mower. Any idea where I can get one from?
http://www.frankballantyne.co.uk/SPAREPARTS.php
You might try the above link. They are in the UK and if they don't have they may be able to point you in the right direction
Oct 03, 2009 | Garden
Ng460 sovereign mower fires up but just stops petrol ok plug ok what next
If it's the little Briggs & Stratton Sprint engine the problem is likely to be the diaphragm that sits between the fuel tank and the carburettor body. They shrink on an incredibly regular basis (usually just outside warranty!) and cause the machine to either not run, or run very rich (as if the choke is full on). If you're competent you can remove the tank/carb assembly, split the two and replace the diaphragm. If not, your local friendly machnery dealer will fit a new one for probably (in the uk) under £30..
Jul 12, 2009 | Garden
Sovereign SLM 1500 lawn mower blades have stopped turning
The belts are available part number is SV150. Call ALM Manufacturing 01423 797208 for advice/stockists.
Apr 13, 2009 | Garden
Garden Logo
360 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
