Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Reprogramming remotes/system i wanted to know rather or not its possible to reprogram the entry control openers/system so that lost ones are no longer useable? i have a chamberlain whisper drive 3/4 hp.
  • Anonymous Apr 30, 2008
    I have a model # 139.53683 reciever & a 139.53681B transmitter that I would like to recode. Your help would be appreciated.
    Del Bernais
    dmbernais@sbcglobal.net
  • parcelgirl Jun 08, 2008
    I have a Sears garage door opener. I need to change the code on the keyless remote pad. Someone help, Please.
    model # 53642SRT
    New Friend:
I have the same problem. There is no manuel because this came with the older home I purchased. I bought a Chamberlain universal remote that requires me to use a chart to determine how many clicks to make to program it. It's not listed. Wrong universal remote? Doyou know how many clicks are required for this?.
Posted on Jun 23, 2013
    Champion:
  • 244 Answers
Yeh, it is called reading the manual. Push and hold LEARN or SMART button for 10 seconds, Release, Push for 1 second and enter keypad code and ENTER, Kight bulbs should blink. Hit learn again for a second and push a button on a remote. Repeat for all remotes.
Posted on Dec 29, 2009
HOW PROGRAM THE KEY LESS ENTRY FOR SONATA 2012
  1. Cars
  2. Car Maintenance
  3. General Car Maintenance
  4. How to Program Keyless Entry Remotes in a Hyundai Sonata
How to Program Keyless Entry Remotes in a Hyundai Sonata By Christian Killian, eHow Contributor
20Found This Helpful The keyless entry system in your Hyundai Sonata is part of the factory alarm system. If you have to replace a lost or damaged remote, reprogramming will be necessary. The remote is important because not only does it lock and unlock the doors, it also arms and disarms that factory alarm when you open or close your car doors. New remotes are available from any Hyundai dealer. While they will program it for you, you can do it yourself and save a programming fee.
How to Program Keyless Entry Remotes in a Hyundai Sonata(Kleophaus Livingston/Demand Media)
Other People Are Reading
Step 1: Locate the fuse panel under the dash on the driver's side of the car. Just below it is the control module for the factory alarm system. Open the cover on the alarm system control module and locate the memory switch inside.
(Kleophaus Livingston/Demand Media) Step 2: Verify that the switch is in the "Off" position; if it is not, switch it to the "Off" position. This is important for the system to understand what you want it to do when you move to the programming mode.
(Kleophaus Livingston/Demand Media) Sponsored Links
Step 3: Insert the key into the ignition of your Sonata and turn the key to the "On" position. Wait for 60 seconds, then move the memory switch inside the control module to "Set."
(Kleophaus Livingston/Demand Media) Step 4: Depress and hold the "Lock" button on your remote for one full minute. This allows the remote and the control module to communicate and sync. Release the "Lock" button and turn the memory switch in the control module back to the "Off" position.
(Kleophaus Livingston/Demand Media) Step 5: Turn the ignition switch to the "Off" position and test the remote by pressing the "Lock" or "Unlock" button, verifying that the doors do lock or unlock.
Read more : http://www.ehow.com/how_6362326_program-entry-remotes-hyundai-sonata.html
Mar 29, 2015 | Hyundai Sonata Cars & Trucks
Bought a used keyless entry remote key fob, how do I reprogram it to a 2008 suzuki sx4?
the operators guide covers this.
lost that? (in the glove box is was)
Jul 02, 2014 | 2008 Suzuki SX4
Keyless receiver
immobilizer control module under the dash.some vechicles if you replace key remote dealership has to reprogram remotes using diagnostic equipment.try this techinique to synchronize remote transmitter. stand within 5 feet from vechicle .press transmitter lock and unlock buttons simultaneously for 7 seconds . system will lock and unlock doors confirming synchronization. if this dont help dealership has to reprogram remotes.
Dec 13, 2013 | 1997 Chevrolet Blazer
Remote starter stops working every few months, I was bringing it in to have it reset every time but shop is no longer open. I would like to know how to reset the unit myself.
Use this procedure to reprogram the remote transmitters
1. Turn "on" the ignition.
2. Press the Valet Switch 5 times and wait for horn confirmation of entry into programming mode.
3. Press and release the "Lock" transmitter button on each remote to be coded (one at a time).
4. The system will respond to each with an audible confirmation.
5. Turn "off" the ignition to exit program mode.
The unit should retain the transmitter codes almost indefinitely and should not require reprogramming periodically. I suggest that you call Omega Research and Development, the makers of Excalibur, to see if your unit can be replaced. Their number is 800-554-4053 and their is www.caralarm.com
Nov 10, 2010 | Excalibur RS-310-EDP Remote Start Keyless...
How do i reprogram electronic door locks
Programming Electronic Door Lock Control System NOTE: The electronic door lock control processor (14B001) erases all previous keyless entry remote transmitter (15K601) from memory when the keyless entry remote transmitters are programmed or reprogrammed. The electronic door lock control processor can store up to four keyless entry remote transmitters in memory.
  • To program (or reprogram) keyless entry remote transmitter into the electronic door lock control processor, perform the following steps:
  1. Turn ignition switch to the RUN position and momentarily short the two terminals of the program connector taped to the wire assembly and located behind the glove compartment. All doors should lock and then unlock. Remove shorting pin.
  1. Press any button on keyless entry remote transmitter. All doors should lock and then unlock to verify the keyless entry remote transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter).
  1. Repeat the above step to program additional keyless entry remote transmitters into the electronic door lock control processor (up to four keyless entry remote transmitters maximum).
  1. Turn ignition switch OFF. All doors should lock and then unlock.
  1. Check operation.
Jun 05, 2010 | 1997 Ford Windstar
Keyless entry doeasnt work
if its factory keyless entry, chances are your battery for your remote need to be replaced, the remote could also need to be reprogrammed... If it is an after-market system, there are several possibilities... wires could be pinched, the door lock solenoids could be broken or misaligned, the "brain" of the system might need to be reprogrammed.
Apr 24, 2010 | 2001 Chevrolet Blazer
Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
May 14, 2009 | Chamberlain 950CB Remote Control
Reprogram a keyless entry remote
Hello
this is how to program the remotes/keyless entry
How
  • Obtain all remote transmitters
  • enter the 5 digit permanent code into the keyless entry pad on the drivers door
  • Press the 1-2 switch on the keyless entry pad
  • Within 5 seconds
  • Press any button on the first remote transmitter
  • The doors should open then lock
  • Within 5 seconds
  • press any button on the second & third remote
  • within 5 seconds for each remote
  • to exit programming
  • simultanionusly press 7-8 & 9-0 switchs on the key pad or wait more then 7.5 seconds
NOTE
The 5 digit permanent code is located in one of the following places
  1. On the owners warranty card
  2. On the label on the inside the trunk/ boot
  3. On the owners code card
  4. On the centrel locking control module located in the drivers door
  5. In the PCM ford can get this for about $25.00
I hope this help
Regards Paul
www.limotec.co.uk
Jan 13, 2009 | 1995 Lincoln Town Car
Door handle stuck
need to remove door panel either the linkage clip either broke or disconnected --if have remote start on fob need dealer to program--if normal try these links
Lexus Free Keyless Remote Fob Entry programming instructions Free Keyless Remote Fob Entry programming instructions procedures for all...
May 13, 2017 | 1998 Volvo V70
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
423 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
