Question about Maytag Neptune MDE5500AY Electric Dryer
Drum is hitting against side of dryer - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryerdrum is hitting against side of dryer - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on Jul 04, 2010
Drum makes loud banging noise.
Maybe the heat in your dryer over time has melted weak glue and loose components are hitting against the drum
Jan 16, 2012 | Frigidaire Electric Dryer
Tip
Fridgidaire and GE Dryer Belt Replacement
Here are the belt diagrams for replacing your dryer belt for Fridigaire and Ge Dryers
For Fridigaire dryers 1970-1985
9b6122a.gif Style: Flat with ribs
Installation Tips: Ribs face toward drum
For 1985-1995
For 1995- present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
For Ge Dryers
1970- 1990 standard capacity
Installation Tips: Ribs against drum
1970- 1990 Large capacity
1990 – to present
on Mar 02, 2010 | Dryers
Tip
Dryer Belt Replacement Replace Dryer Belt Admiral Amana Asko Crosley ...
If you need to replace your dryer belt and need a diagram to see how it goes, check out these diagrams.
For Admiral all models will look like this
154ceff.gif Style: Flat with ribs
For Amana all models will look like this
For Asko all models will look like this
For Crosley all models will look like this
Fridgidaire
1970 – 1985
1985 – 1995
1995 – present
Style: Flat belt
Dose the dryer belt have a twist in it coming off the pully so that flat side of belt is against the drum and the grooved side wraps around the drive or dose it matter if the grooved side is also against...
The grooved side should be in contact with the drum as well as the drive pulley. And blank/flat side of the belt should be in contact with the tension pulley.
Dec 31, 2010 | Samsung Dryers
Does the flat side of the belt go against the drum of a maytag dryer or does the serpentine
If the belt has grooves cut into it, then the grooved side goes onto the drum, and the flat side facing uppermost.
Dec 29, 2009 | Maytag Dryers
What is the correct belt routing for a maytag MDE6000AYW dryer and should the groove side or smooth side be on the drum? Thanks. dave
groove down. around the drum. near the motor you will find a tensioner. Through the tensioner then around the pulley on the motor. Have your assistnnt hold the drum up while you get up and prepare to put the front back on. You know the rest.
They call it a tensioner for good reason ... you may want to lift it using the length of a screw driver against the floor of the machine.
Watch your fingers.
If you are happy with this answer, please leave positive comments
thanks
a
Oct 14, 2009 | Maytag MDE6000 Dryer
Need belt diagram for Performa PDET920AYW dryer
Flat side of the belt goes agaist the drum. The diagram is on the new belt
Aug 08, 2009 | Maytag PYE2300AY Electric Dryer
Do you have a digram to show you how to change belt on inglis dry
amana.gif Diagram A
transparent1.gif frank.gif Diagram B
transparent1.gif frig.gif Diagram C
transparent1.gif ge.gif Diagram D
transparent1.gif maytag.gif Diagram E
Installation Tips: Flat side of belt against drum
transparent1.gif admiral.gif Diagram F
transparent1.gif westing.gif Diagram G
Style: Flat belt
transparent1.gif whirlpool.gif Diagram H
belt1.gif Diagram J
belt2.gif Diagram K
belt3.gif Diagram L
belt4.gif Diagram M
Jun 25, 2009 | Whirlpool Inglis IP8200 Dryer
The belt has come off the dryer drum. I dont know how the tensioner goes back on
stick the belt pulley in the holes closest to the motor. if you have a belt pulley like this. get the belt and hold it together so you have a loop at the end and run under the pulley so the pulley lifts up and put the belt on the motor shaft. the belt always goes under the pulley so you are lifting upwards
Jun 21, 2009 | Dryers
Maytag dryer making clanking noise
I had this problem and the cause was a loose screw holding on one of the "paddles" inside the drum. I removed the door, front panel, lifted the top, manually rotated the drum until I saw the screw head which had worked loose and was slapping the side of the dryer. A quick tighten of the screw and the noise was gone.
Jan 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
108 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
