Question about kawasaki Garden
I need to adjust the govenor on my 17 hp vertical shaft kawasaki engine
4 Suggested Answers
  • 246 Answers
SOURCE: canaballing parts
Hello tim38663:
Depending on the Engine Model and Spec this Tecumseh Usually has the Same External Parts as a 15 HP to the 18 HP Single Cylinder Tecumseh Engines.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
lester482529
  • 226 Answers
SOURCE: briggs and stratton engine smoking
if your oil level is to high it will do this. i would drain and refill the oil to oem specs slowly as not to overfill so it doesn't blow over the top of the piston.hope this helps
Posted on Jun 25, 2009
nova2nv
  • 197 Answers
SOURCE: engine will not run at steady speed, govenor
On top of carb you will see a jet that is slotted,remove with screw driver and use a very thin wire to clean out hole in jet.Some had a black metal clamp holding it in place,remove that one by removing phillips screw,black clamp then use small pliers to pull jet out of top side of carb.If this does not work remove carb bowl and jetting in bottom-center of carb and clean jetting holes with a small copper wire.The mixture screw is for low speed air/fuel mix,this engine does not have a high speed fuel screw.Fixed jet.
Posted on Dec 11, 2009
ADJUST THE GOVENOR ON MY LT 155 John Deere lawn tractor
This should be Kawasaki engine; although, it could a Kohler. The IPL on this doesn't specify which engine it has. It would nice if it did where I could look the engine's service manual but the following should be what you need.
You place throttle in full throttle position. You need to watch the linkage at the governor shaft for which it turns as you go to full throttle then you would continue turning the governor shaft in that direction until it stops. From there you tighten the retaining bolt or nut and you should be good to go.
Nov 08, 2014 | John Deere Garden
I have a 18HP B&S Vangaurd Vertical shaft on a scag walkbehind motor runs good untill I engage the blades then it seems to draw down to about half throttle until I disengage the blades then the motor...
Check the govenor spring to see that it is not stretched out or popped off...there should be a colored spring on the throttle plate where the throttle lever connects to...also, there are several holes in the plate where the spring attaches...these hole will set the sensitivity of the govenor...you may need to make it more sensitive to hold the engine speed high when engaging the blades
May 11, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
My engine is pulsing I removed the jet and cleaned with compressed air and cant figure out why it still surges at low rpm
it is a govenor problem i would just lift the revs slightly and try adjusting it out with air mixture screw
May 04, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine races
One thing I read is that on some the arm from the govenor shaft can slip on the shaft so the arm is rotated on the shaft to a point the govenor isn't even in contact with the internals driving the shaft. On those units a clamp bolt becomes loose causing the problem.
I suspect if there IS an internal problem it is severe and one would have to disassemble the engine before operating it lest damage occur from loose parts.
Mar 24, 2010 | Briggs & Stratton Power Products 5,550...
I HAVE A JOHN DEERE LX188 MOWER. 17 HP. GOVENOR NEEDS ADJUSTING.
Your engine per John Deere is a Kawasaki FH500V
Here is the service manual (3.58 Mb pdf file) This should get you going again.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Jan 23, 2010 | Garden
Throttle control not operating.
Need more information. Is your cable hooked up to the carb or broken? Try checking that. Rick
Apr 06, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
197 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
