Question about Sova Digital DST207-S37C Television
Have a sova 32" LCD flatscreen, purchased in 2007. Visuals went out on it, although sound continues to work. Fixable?
  • Anonymous Mar 24, 2014
    my 32' suddenly went black in front of me but I still have sound but no visual...E326XZNK
    Invision Series AOC
  • Sova Master
  • 5,382 Answers
Possibly. Did the problem start suddenly or did the picture fade (possibly with a pink/red color)? The problem was sudden, it probably was the inverter that drives the backlight. If it slowly faded, the backlight itself failed. Most manufacturers will recommend the entire board be replaced if it is the inverter. The inverter is simple to replace but you must get the right one for your tv. (The replacement is disconnect the wires from the old board (like molex plugs) and unscrew the board. Screw in the new board and connect all the wires.) The backlight is a bit harder since you have to use a rotary tool (Dremel) to remove the old one from the housing.
First open up the TV and remove the shielding. Look for any capacitors that are bulging or leaking. (These are cylinders on tripods.) If you see those, note the part number of the board and order a new one. Match the part number and revision if possible. Universal inverters are available but you may have issues like the contrast and brightness being reversed (press up to reduce brightness). (Depending on the inverter they range from $50-$150). You could alternatively just replace the capacitors and usually the resistor that served as a fuse for the board.
One way check the inverter is with a multimeter that can measure frequency. (You need a high frequency range ~50 kHz, Alternatively an oscilliscope can do this.) Hold the multimeter probes a fraction of an inch apart about an inch above the circuit board with the TV plugged in and on. If the inverter is bad or the frequency is too high for the multimeter, you will see a result near zero. If the multimeter gives a measurement of 1 or a value of 20-60 kHz (depending on the TV), it's probably the backlight.)
I hope this helps.
Posted on Jul 03, 2010
22" flatscreen LCD Westinghouse TV.
try use a lowest resollucion 720p and after change to 1080
Sep 20, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Our vizio flatscreen tv just went off and won't come back on.
Look and see if the fan is working on the inside.
It may a built-up of dust.
Thanks,
Wbigtodd
Jan 01, 2010 | Vizio L32 32 in. LCD HDTV
LOOKING FOR A AC ADAPTER FOR SOVA LCD 30" TV
lcd paylessi found a place to replace power adaptors for sova 32 in lcd.
Nov 15, 2009 | Sova DSV32P112 32 in. LCD Television
26 inch sova lights go on but no picture or sound.do i throw away this lemon?
No. There is a switch located at the bottom that allows you to reset the TV.
Jul 04, 2009 | Sova DSV32P112 32 in. LCD Television
Sova LCD 32" with no Picture
since i do my stuff by trial and error, sometimes its just a matter of making sure you dont have a video cord plugged into an audio plug that is supposed to be for the tv signal to go out and not come in or that where you have the left/right audio plug is good, but the video plug is broke.
i just move from one slot to the next trying different a/v (out) spots
Sep 12, 2008 | Sova DSV32P112 32 in. LCD Television
Need Screws for SOVA LCD TV
i need a borad for my sova 32' lcd tv
Mar 26, 2008 | Sova DSV32P112 32 in. LCD Television
Sova Digital DST207-S37C Television Logo
61 people viewed this question
Top Sova Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sova Televison and Video Expert? Answer questions, earn points and help others
