Question about Dryers
Whirpool elcetric dryer takes twice as long as previous to dry clothes. Seems to get warm enough and is tumbling.
  • fwilson923 Jul 07, 2010
    twice as long as this dryer used to take.
  • 46 Answers
It could be that you have a bimetal switch that is not letting your dryer get warm enough. Many times the problem lies in the exhaust vent or hose being plugged with lint. There are two thermostats or bimetal switches. One controls the heat level and switches the heating element on and off at a specified temperature and the other is a high limit safety. It could be that you have a defective heating element but most of the time they either work or they don't . Always check your exhaust vent before looking for a more serious problem or calling a repairman.
Posted on Jul 03, 2010
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
Whirpool dryer takes 3 hours to dry jeans or towels.
Most likely your heating element has partially failed. Some dryers have two separate resistance heaters in them. If one fails what you are describing can happen. If you have the tools and are willing to take it in it's not that bad a job. You have to take the cover off the dryer to see it, then it is two bolts. Any appliance repairman can handle this easily.
Mar 22, 2010 | Whirlpool LER5636P Electric Dryer
Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Aug 21, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Some heat, not enough
you have a lint problem recommend cleaning the whole dryer and the best thing for the lint screen is toilet bowl cleaner... weird i know but it works really well..
Apr 30, 2009 | Dryers
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
