Question about E-Machines eMachines Desktop PC
The T4010 emachine does not recognize the keyboard, but does recognize the mouse, is the answer a new motherboard?
    Brigadier General:
  • 10,406 Answers
If replacing the keyboard (try a USB keyboard, instead of a PS/2 keyboard) does not help, and the old keyboard _does_ work when connected to some other computer, then a new motherboard is the next logical step.
Posted on Jul 03, 2010
Why msi motherboard not recognizing keyboard?
The simple answer is to try a different keyboard first just to make sure that the problem isn't the keyboard. If it still doesn't work go into the BIOS and change the settings to report an error if no keyboard detected, if it says it can't find a keyboard during the boot process, then you may have a problem with your hardware/BIOS chip
Aug 18, 2014 | Micro-Star MSI 760GM-P34 FX Desktop...
My motherboard 945gct-m/1333 v3.0 doesn't recognize the PS2 keyboard and USB mouse.
Hello Nelson, most likely you may need a new motherboard. But here are some thing you may try before considering on buying one,
  1. try replacing a new motherboard battery.
  2. reset you bios. locate jumper cmos battery.
let me know your progress.
Nov 24, 2011 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
My computer wont recognize new wireless mouse
Make sure the batteries are inserted correctly and have charge
make sure the usb device is properly inserted
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a button or switch on top or bottom also you might try safe mode
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
hope this helps
Nov 20, 2011 | Computers & Internet
Mouse & keyboard not working
You're "stuck" -- if the circuitry for the PS/2 keyboard and mouse is not working, and if it does not recognize a USB keyboard, the motherboard must be replaced (by an identical moetherboard, if you can find one, or a "newer/better" motherboard that takes the same CPU and RAM as your current motherboard).
Jul 30, 2010 | MSI PM8M-V Motherboard
When switch on desk top computor it bleeps saying unable to detect mouse/keyboard but mouse lights up
This can be caused by loose connections or a failure on the main computer motherboard. With the computer off pull the keyboard and mouse connections off and then reinsert them. Boot the computer and see if it finds them. Also try a differant keyboard and mouse.That will tell you if it is one or the other that has the problem. If you still cant use the keyboard or mouse then you have a more serious problem and are most likely looking at replacing the motherboard. Check to see if you have any warrenty either from IBM or the store you bought from.
Mar 23, 2010 | E-Machines eMachines Desktop PC
Emachines model t4010 window s xp. need a driver
plz kindly specify your ethernet card model so that you may get assistance
Nov 10, 2009 | Computers & Internet
When I restart my computer It does not detect the keyboard/mouse
Sometimes, USB Keyboard and USB Mouse give such problems. Try using conventional (PS/2) Keyboard and Mouse.
Mar 29, 2009 | Computers & Internet
Mouse and keyboard not working / recognized by computer
If its an USB keyboard and mouse, try to insert keyboard in upper port and mouse in lower port USB.
Sometimes when they Both are inserted in port in same line, they are unable to Fetch equal amount of power.
Try this and do restart your computer, after inserting them in USB ports.All the Best
Jul 02, 2008 | E-Machines T3624 PC Desktop
Bios does not find PS2 keyboard/mouse
Did you go into the BIOS and set it to recognize the USB Keyboard after you reset the BIOS? Is windows not noticing it or the BIOS. You stated that it recognized the USB keyboard and then said that it did not.
What does all of this mean? USB keyboard does not activate "del" setup.
If it does not work, it is because you reset the BIOS and did not change the settings back for the USB keyboard.
I hope that I fixed your problem.
Jun 04, 2008 | AOpen AX4BS (91.32Q10.002) Motherboard
Mouse and Keyboard not recognized
i think ur computer hangup after booting
there may be some problum in ur op system . it hase virous.
2nd u test ur mouse and keyboard to another computer if they work correctly u have to reinstall ur op sys
u can call me 91-9329204658 india
Jun 01, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
286 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
