Question about HP Pavilion dv6000z Notebook
Convert the same unit of measure and express the ratio in lowest term. 8 inches to 2 feet
    Genius:
  • 1,970 Answers
Mcdevito75 here, That would be 24 inches at a ratio of 3 to 1.
Posted on Jul 03, 2010
How to Calculate Compression Ratio?
It is calculated by measuring a piston at the lowest point in its travel (i.e.8 inches) then measuring again at the highest point of travel (i.e. 1 inch) Then compare the two readings = 8 to 1 ratio.
Oct 14, 2016 | Cars & Trucks
Can someone tell me what the square footage is in a board 2 inches thick 8 inches wide and 8 foot long please
if you are staining the edges and both sides it will work out as follows
Each flat side is roughly 5.28 square feet or 10.5 square feet total per board.
The edges add rougly another 2.4 square feet so rough answer would be 13 square feet per board.
Jul 10, 2016 | Office Equipment & Supplies
I HAVE DOUBLE DOOR UPRIGH REFRIGERATOR TTELL ME FORMULA HOW TO KNOW REFRIGERATOR SIZE IN CUBIC FEET
If you measure the height, width and depth you can calculate the volume. You multiple the height by depth by width. Make sure you use the same units for each measurement. For example if you want the volume in cubic feet, make sure all measurements are in feet. If the height is 5 feet 8 inches, you need to convert this to feet, which would be 5.67 feet, likewise for the other two measurements. It wont be exact because there will be bits sticking out but will be near enough. Make sure you also calculate the volume of the door space as that is included in the volume.
May 21, 2016 | Refrigerators
I need the Linear feet: It measures 24" tall, x 10" thick, x 15 1/2" wide. Can you help?
linear feet is a length measurement as to how long it is --example : a piece of timber 20 feet long is 20 linear feet
the measurements you have provided will give a cubic feet measurements which is a volume measurement. so convert all the dimensions to feet , multiply all together and that will be your volume
May 03, 2016 | Luggage & Travel
How many linear feet is in a piece of carpet that is 5'x7'7
Linear feet (often called Lineal feet) are the same as regular feet. No conversion is necessary. If something is 6 linear feet tall, it is 6 feet tall. FAQ What is linear feet How do convert it to feet FAQ What is linear feet How do convert it to feet
Nov 24, 2015 | Measuring Tools & Sensors
What would 150 letter size sheets convert to in cubic feet measure
8x10 x whatever the height of the package is= cu inches. divide by 12 to get cu.ft.
Jun 18, 2015 | HP Office Recycled White 8 1/2 x 11 Inch...
How many feet is 350 linear feet?
Linear feet are a measure of length (no different from feet); square feet measure area. You cannot simply convert between measures of different kinds of quantities;the connection between them will be specific to a particular problem.A practical example in which this question can arise is in buying countertops for a kitchen. Some materials are sold by the square foot; others (basically those that are extruded, so they come in standard widths) are sold by the linear foot. In order to compare the two, you need to compute the area and wall length for the countertop you want.You can't convert between the two. All you have to do is to make the appropriate measurements so you can calculate the price of each item.The terms used in the lumber industry are a bit confusing.There are two terms that I think you might be mixing up.A LINEAR FOOT is simply the length of a board. If you want to know the area or volume of the board,you need additional information. For instance, 6 linear feet of 1-by-12 has an area of 6 square feet (12 inches = 1 foot, times 6 feet), and it's 1 inch thick, so the volume is 1/2 cubic foot (6 square feet times 1/12 foot). But 6 linear feet of a 1-by-6 board would have half the area and half the volume.A BOARD FOOT is equivalent to one square foot of a 1-inch-thick board. In other words, it is a square-foot-inch (ft^2-in), or 1/12 cubic foot.Linear feet are used for the pricing of a single size such as two-by-fours. Board feet are used for larger lumber that you are more likely to want to compare directly with different size boards .To sum up, neither a linear foot nor a board foot can be converted directly to square feet. A linear foot is a linear (length) measure, and a board foot is a volume measure. You need to know your particular board to do anything more, such as find the area.an example with an" L" shaped countertop will betwo rectangles are 24 by 80 inches and 24 by 36 inches. Thus the area is: 24 * 80 + 24 * 36 = 24 * (80 + 36) = 24 * 116= 2784 sq. in.To get it in square feet, divide by 144:
2784 / 144 = 19.33 sq. ft.The linear measure of this countertop would be 60 + 80 = 140 inches = 140/12 feet = 11.67 feet
Apr 08, 2014 | Cars & Trucks
Ratios
1/25 IS the ratio of 1 to 25. There is not much you can say about it.
Can it be reduced to simpler terms? No! because there no factor common to the numerator (1) and the denominator (25) which you can simplify.
So 1/25 is in its reduced form.
Case of the ratio 2/100
It is clear that we can write the numerator as 1*2. To hope to reduce the ratio to simpler terms we must be able to find a factor that is common to the numerator and the denominator.
Although 100 =1*100=2*50=4*25=4*5*5 it is clear that the only factors common to 2 and 100 are 1, and 2.
To take 1 amounts to doing nothing, but if we take 2 we can write
2/100= (2*1)/(2*50)
Simplifying by 2 (the two 2 cancel each other) we get
2/100=1/50
That is the reduced form.
May 26, 2010 | Vivendi Excel@ Mathematics Study Skills...
Cubic feet
4' = 48"
thickness" x width" x lengh" = cubic inches
2" x 8" x 48" = 768
1 cubic foot is 144 cubic inches
768 divided by 144 = 5.3333333333------
Dec 09, 2008 | Electric 1/2hp 1140RPM 56 Frame 230/460V...
HP Pavilion dv6000z Notebook Logo
26 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
