Question about Microwave Ovens
Magic Chef over the range microwave oven MCO153UB less than two years old touch pad isn't working to set time or start oven,although if we push the automatic start buttons like beverage or popcorn, it will run. Any suggestions?
Richie_asg1
  • 1036 Answers
SOURCE: oven turns off
You are running the risk of damaging the Magnatron by doing this.
Check the packets you are using, you will have to reduce your power output.
This is because microwaves act by being absorbed by water. There is very little in popcorn and in fat. Once this has been evaporated, the microwave energy builds up (as it is still being produced - but not absorbed), and ends up cooking the magnatron itself.
I have seen countless posts on here after cooking popcorn!
More fun on the hob anyway - and cheaper to buy in bulk!
Posted on Jun 21, 2008
SOURCE: display has a f2 code on it. whirlpool oven is model mh1150xm and less than 3 years old.
determined from whirlpool that the f2 display is from the control circuit board. the board's problem is intermittent and needs eventually replacing. not covered by warranty. determined that whirlpool has reduced the warranty for the electronic circuits in its appliances from 5 to 1 year. this is great for consumer confidence in whirlpool. have had trouble with 2 other new whirlpool appliances. probably will not buy another whirlpool appliance.
Posted on Aug 04, 2008
SOURCE: magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Posted on Sep 17, 2008
dmftrucker
  • 1922 Answers
SOURCE: My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
Posted on Jul 27, 2009
97F350diesel
  • 1326 Answers
SOURCE: magic chef over-the-range microwave shut off
Sounds like its possibly overheating and causing a thermal shut down, possibly drawing more power then was designed and also causing the shut down. In any case there are no user servicable parts in a microwave. I would have it replaced or repaired if cost effective. In any event it poses a serious danger due to microwave rays and possibly the leakage of those rays. I would recommend not using the microwave due to safety concerns
Posted on Aug 07, 2009
Microwave key pad won't work
That is a failed membrane keypad.
It is part number 3518522640B and you can order it from the Pros here.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this repair for you, we do that for $39.95 plus parts.
Aug 22, 2012 | Magic Chef Microwave Ovens
Appliance will not heat,but operates
The problem is in the magnetron the heart of the system, or the inverter board, if microwave oven is 7 years old or less.
Jun 08, 2012 | Magic Chef CMV1000B Microwave Oven
My Maytag Microwave is blowing the 250v- 20a fuse behind the key panel on the black wire. It melted the fuse holder mounted to the main body of the unit. Any thoughts on why?
The magnetron is shorted, the keypad control board is bad, blowing fuses. If less than 7 years old it has a inverter board that can be trouble, But with the level of work and parts it will easily exceed the cost of a new microwave oven.
Apr 07, 2012 | Magic Chef CMV1100 Microwave Oven
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Dec 23, 2009 | Magic Chef CMV1000B Microwave Oven
I was making popcorn and the microwave just died
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jun 07, 2009 | Magic Chef CMV1000B Microwave Oven
MICROWAVE TURNS ON BY ITSELF AND RUNS FOR 3.5 MIN EACH TIME
My Magic chef Microwave also starts by itself the the keyboard locks up.
We have had this unit for 4 years with no problems. I called Magic Chef and they are sending me a new brain for the unit and then someone will come to my home and repair it. NO CHARGE! I am very pleased that they are backing their product like this. God Belss America
Dec 10, 2008 | Magic Chef CMV1000B Microwave Oven
Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
Nov 24, 2008 | Maytag MMC5000 Microwave Oven
Magic chef touch pad doesnt work
I don't have Magic chef, however, I would try hitting cancel, unplugging the microwave and waiting a few minutes, then plugging it back in to reset it. Alternatively, you could go to your manual under troubleshoooting. I wish that I could help you more with this. Good luck to you. Please let me know if you figure this one out.
Jul 31, 2008 | Emerson MW8626W Microwave Oven
Cook time button problems
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Please reply back here and let us know if the hard reset doesn't fix it.
It may have a bad door switch, and we can help you check into that. The first test for that is to try it while gently lifting up and then while gently pushing down on the door.
If you don't have your owner's manual, you can download it here:
http://www.mcappliance.com/products/otrdetail.asp?record=yes&modelname=MCO153UB
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 11, 2008 | Magic Chef MCD1311ST Microwave Oven
Microwave Ovens Logo
76 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
