Question about Cell Phones
I have a Motorola Razr V3XX cell phone and I can,t turn it on Battery is good. I bush the on button and nothing happens. Can you fix. Thanks Hacress@verizon.net
  • 5 more comments
  • Hacress Apr 17, 2008
    Have tried that and still dosn,t work. What next
    I tried your solution and it didn,t work. The battery light comes on but still can,t get the phone to light ip. What next?
    I tried this and still dosn,t work. The battery is fully charged.
  • Hacress Apr 18, 2008
    Have tried all of these things and nothing works. The battery is good, the charger is good, what else is there. Have cleaned all the contacts and did everything you have told me to do. ???
    I have tried all of the things you recommended and nothing works. Where do you recommend I get it repaired.
    The phone isn,t under warrenty as I got it from my friend in Florida a couple month ago. Now, where is there someone that can repair the phone thats not under warrenty?
    How do I clean the keypad board?
  • 818 Answers
Check battery contacts, here can be the problem.
Sergio
Posted on Apr 17, 2008
    Brigadier General:
  • 3,614 Answers
Press and hold the
power key P for
2 seconds to turn the
phone on.
Note: It may take up to
4 seconds for the
display to illuminate after you turn the phone on.
  • 2 more comments
  • micromaster
    micromaster Apr 17, 2008
    which of the solution you have followed, #1,2,3..?
    thanks
  • micromaster
    next....
    remove the battery into the cellphone..
    try to power it up 3x w/out the battery, to release/reset some of stored extra power on the fone.
    then put it back again the battery into the cp and power on again..
    BTW...how old is your cp now..?
    Post back again..
    Thanks
  • micromaster
    ...& another thing, are you sure that your cp battery was not discharge..?
    --after you do the 2nd step, try this one... fully charge your battery..
    thanks
  • micromaster
    micromaster Apr 18, 2008
    cleaning on the keypad board will fix the problem.
    Genius:
  • 3,422 Answers
HI,
Remove the battery first and then put it back after 10min.Charge the battery and then hold the power button for 1min.
I hope this helps.
Goodluck..
  • 3 more comments
  • Priya darshan Apr 17, 2008
    See,now the problem can be with two things either the battery or the charger.You can first try to replace the charger and see if that charges the battery properly.If not then it is the battery you will have to replace it.
  • Priya darshan Apr 18, 2008
    Let me tell you one thing the problem can only be with the charger or the battery until and unless you try to replace and then check it you cant be sure.
    If you still face the problem then the only solution is to get it repaired or replace it if it is still under warranty.
    Goodluck..
    I told you before if it is under warranty then just return it back to the dealer from whom you purchased
    Go down the page and on the right side you can see a repair service box in that enter your zipcode and you will get a list of service people you can dchoose from.
    Goodluck,
    Please don't forget to rate the solution.
    To clean the keypad board you will have to take the phone apart..
My motorola V3xx phone hang and so i get the battery so that it will be on again but then when i switch it on, the keypad is lighting but there's nothing that can be seen on the screen.. please help me...
This is a common glich with razr models, if you have insurance request a new phone. It is not the battery or charger it is a malfunction in the power port on phone. Not repairable
Nov 06, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
My motorola razr v3xx crashed while downloading skin now i have nothing
I take it that the phone is bricked? check out modmymoto . com . They have tons of excellent info that may be able to get your phone back.
Jan 24, 2010 | Motorola Mobility RAZR v3xx Cell Phone
V3xx wont turn on tried 2 batteries and plugged in nothing
There might be corrupted files or system that's why its not able to switch on. Try to get it fix.
Jan 19, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
V3xx Razor wil not turn on
you need a master eset for you phone. I have the new Prada Lg Phone and has the same problem. Only Motorola can reset it and it will be expensive
Aug 23, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola V3xx Razr Front LCD Screen Glass Repair
Your best bet would be to take it to your cellphone company and have them fix it for you.
Jul 03, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Razr v3xx celluar
Usually that only happens if the phone was just turned on, so the camera takes time to warm up. Try restarting your phone and try again. Hope this helps =)
Feb 25, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Only button that works is the end button
my old razr did something similar to this and they had to send me a new one. :( sorry.
Dec 14, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Razr V3XX rebooting iteslf
hi
it seems your phone has a hardware problem... usually its flash ic.. have it reworked...
hope it get better...
Oct 15, 2007 | Motorola Mobility RAZR V3
Motorola RAZR V3xx not powered on
you need to charge a phone over night for the battery to fully charge and have a memory
try plugging in as charging and turn phone on by holding the red button down for a few seconds on the right hand side
Oct 11, 2007 | Motorola Mobility RAZR V3
Some buttons on my keypad stopped working!
you need to take the phone and have the flexcable replaced on the phone.
Sep 20, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
