Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My remote and indoor switch dose not work I hear a click sound when from the opener but it does not open
  • 201 Answers
most times when you hear a click the logic card is fried and would need replacing. The side where all the wires run to is the logic card. the part number is written on the outside, you can try looking online for them and they are pretty easy to replace. A repair company may charge you as much as a new opener or more to fix.
Posted on Jul 04, 2010
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Ga759wjsa, volume button dosen't work
First switch on a radio receiver which has AM ( medium wave band)
and if the remote controls batteries are good then ,,
tune the MW / AM to lowest frequecy and then start pressing buttons of remote control one by one. for each button pressed you will hear a sharp sound and the button you don't hear a sound in the radio speakers is the faulty one.Then open remote control ( that is if you know how to ,you may have to open few screws and also pry open some plastic latches .Best to take help from one of your friend who had already opened some remote control .)
clean contacts of control pad of remote control with Iso- propyl alcohol.also called as IP.use sergical cotton which will be clean enough.claen also PCB with IP.after drying for few minutes assemble it.take care not to tear the rubber control pads and do to use sharp instruments to clean any parts of the remote .
happy hunting
shekar
Jan 09, 2014 | Sharp GA759WJSA Remote Control...
My webcan dose not work
If your sound doesn't work you need to go to you webcam and switch the brand by open your webcam and click settings click recording and switch it. that's if when you record you cant here yourself. If you cant open your webcam go to start and start typing webcam and it will pop up! Hope it helped!!!!
Apr 21, 2013 | Gateway NV5378u Notebook
2001 pontiac grand prix trunk release dose not work remote or inside car no power at release in trunk.
Sounds as though the motor may have quit working, check your fuse or the relay in the underhood power center. The key still works correct? Do you hear any noise when you try the remote switches? If you do the rods may have come loose or the holders may have broken.
Feb 16, 2011 | 2001 Pontiac Aztek
Indoor unit light blinking ( first n second light from top)
I have the same problem too. Aircon cannot switch on, two lights from the top is blinking. Everytime I turn on, the flip is open then close again with sound. The technician said the thermostat cable need to be replace. It cost about $15. The cable is 14" long. Hope this help.
Feb 16, 2010 | Samsung Heating & Cooling
Remote trunk wom't open. Car is in park.
sounds like a fryed switch in the trunk
it is only a pop switch in the trunk and they do break
Jan 01, 2010 | 2001 Buick Century
Can not switch on home air condition with remote and no have manual switch
If you open the front panel of the indoor unit (it opens upwards) near the receiver there is a samll on/off push button (switch). If the indoor does run but still cannot be controlled by the remote, there is a reciever board problem. you need to call their servicemen.
May 28, 2009 | Cfm Daikin R410a Split System Air...
I am trying to play Marin Party 8 and it won't connect another controler.
turn on your wii with mario party 8 disk in thje wii click the home button click wii remote setting then click reconnet fallow what the screen tells you with all four players then start mario party 8 if this dose not work then have all the players open the back of there wii remotes open the little slot below the disk place there will be a red button matching the one on the back of the wii remote have each player one at a time move up to the wii click the red button on there wii remote and the red button on the wii at the same time after all the players do this then start mp8. if this dose not work your wii is messed up. P.S (this work almost all the time)
From,
cutECAT333
Jan 17, 2009 | Nintendo Mario Party 8 for Wii
Craftman Garaged Door Unit Stopped Working
This sounds like you will have to replace the logic board. Whether you repair or replace get a surge protector 900 joules or higher unless you want it to happen again. You can get replacement parts at searspartsdirect.com. Thanks BB
Oct 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
106 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
