Question about Carrier 38CKC060 Air Conditioner
L6 code carrier air conditone L6 code
  • mrmrmrk Jul 03, 2010
    the L6 really was LB and that idicated low battery in the thermostat box in the house replaced battery and the unit went right to work
    President:
  • 1,515 Answers
Hi, this is a 5 ton unit you have. Is this L6 code coming from the indoor units circuit board? If so, remove the panel where you see this if there is a red led light that is blinking. It may kill power if you remove the blower panel as most have a kill switch for safety to shut all down when removed. To have the power on to check things you will need to tape this switch down good. I am not sure on your unit where you see this L-6 code, but on the panel there should be a trouble shooting chart telling you what this code is telling you. I know on gas furnaces they will tell you the problem. If this code is at the thermostat, you will need to go through the manual for programming it and it will say. Is the system cooling good, no problems that you have found? You might do what I have asked and if its on the stat check the manual. If you don't have one, get the name, Model, Serial numbers from the stat and call a appliance parts house not a sales show room, but a place that sell parts and they can look it up on there computer and tell you what the code is for that stat. Unless the unit has stopped cooling completely, I wouldn't worry to much, but would do your best to find out. If you can, let me know where you are seeing this code and how the system is working. This would be helpful for me. Please be kind when you go to rate me as that would be very kind of you. Please keep me posted on this unit. I will be around here if you need more help.
Sincerely,
Shastalaker7
A/C, & Heating Contractor.
Posted on Jul 03, 2010
Testimonial: "was helpfull considering he did not have the correct infor. and he was correct in his analysis"
  • Robert Horton
    Robert Horton Jul 03, 2010
    Great, I am glad you saw that it was a B. Best to you and have a good 4th!
    Shastalaker7
Unlock code
You can unlock your Motorola cell phone in a cheap and easy way without having much technical knowledge :
Unlock Motorola instantly Unock code for GSM carries Cheapest Price
Jan 31, 2014 | Motorola Mobility L6 Cellular Phone
Reverse rotatin on fan motor aire flo air conditoning model #20402077insol knew capasitor 3 tipe capasitor capasitor /hern/fan/c/
When the capacitor goes bad it can cause the fan motor to run backwards, the capacitor needs replaced.
Sep 24, 2011 | Carrier 38CKC036 Air Conditioner
When the air conditon unti is turn on the unit only hum. I f you turn the fan it will start turning. carrier 38ck024330
In most cases, the fan has a capacitor to assist in the starting. Check if the capacitor has a bulge or is leaking. If so, it is bad. Although, even if the power is dissconnected, THE CAPACITOR HAS A HIGH VOLTAGE CHARGE STILL IN IT! Discharge the capacitor by shorting the two leads together with an insulated screwdriver. Remember, if not comfortable, call a certified hvac technition. In some cases, if no bulge or leaking is obvious a tech will have a microfare tester to further test the capacitor.
Mar 19, 2011 | Carrier 38CKC060 Air Conditioner
Unlocking motorola l6
This phone unlocking site has tons of guides on how to get free unlock codes from your cell phone carrier as well as some other methods. Check it out before paying high prices for an unlock code!
Oct 20, 2010 | Motorola Mobility L6 Cellular Phone
Air conditoner won't go on and receiving E2 message on panel
E2 code is 24 volts loss. Check transformer and control voltage should be 24 volts.
Jun 05, 2009 | Carrier 38CKC036 Air Conditioner
Subsidy code for motorola l6 slvr
You will need to contact the carrier or go to a third party company and pay a small fee to get it unlocked.
Feb 12, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Sep 01, 2008 | Carrier Heating & Cooling
Moto SLVR L7c security code
you can call your carrier and they can give you an unlock code for it.
Oct 19, 2007 | Motorola Mobility L6 Cellular Phone
Carrier 38CKC060 Air Conditioner Logo
430 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
