Question about Vizio GV46L 46 in. LCD Television
Faulty power supply unit?
My Vizio GV46L after one year stopped working and it's not under warranty now. It seems like it doesn't get power. I already tried switching different outlets and power cords. Could it be a faulty internal power supply unit? Does anyone know when I can purchase one? Does anyone perhaps know how to fix it? Thanks.
  • Anonymous Feb 24, 2009
    I have a Vizio GV46L which is about a year and half old. It just went dead without any warning. I have changed outlets, plugs it is still dead! Help
    Sergeant:
  • 395 Answers
This unit uses one of 2 power supplys the parts list is here https://www.vancebaldwin.com/shop/research_new/VIZ/GV46LHDTV10A.pdf
you can purchase the parts at www.vancebaldwin.com. but before you order the power supply check the voltages on the power supply you should have 24v, 12v, 3.3v, and 5v if you have all of these voltages then you may have a main board or panel problem.
Posted on Apr 17, 2008
    Genius:
  • Vizio Master
  • 1,689 Answers
You can contact the manufacture to purchase the power supply module.
However, there are other boards in the set that can easily cause the power supply failure because something went defective. It is also possible that the power supply is not defective, but it is in protect mode because of a failure on another board, or in some other device in the set.
The tech would follow procedure from the service manual using the proper instrumentation and diagnostics to determine the defective board(s). Then he would replace the necessary modules and or parts to get the set working again.
In the end if you try fixing this yourself, you can end up spending a few hundred dollars on a power supply and only find that it blows again or goes in to protect mode because the original fault was not determined and corrected.
Jerry G.
My vizio tv will not turn on
I have repaired many of these over the years. Vizio s have regulators on the main board that have been failing causing this problem. You can verify that the power supply is working by the Vizio em-bloom lighting up on the front of the set. Hope this helps. :)
Apr 28, 2017 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Our 4 month old Frigidaire FRA256ST2 stopped working today.We had an eletricain check the plug and the unit is getting power.When you plug it in and press the reset,it beeps,LCD flashes but doesn't...
A dirty or clogged air intake filter will prevent the unit from turning ON, as a safety feature. If that isn't of doesn't solve the problem. Contact Frigidaire 1-800-944-9044. As you unit is still under 100% warranty at this point. They will repair it or replace it at their option. Don't do anything to the unit, that could possibly void the warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | Frigidaire FRA256ST2 WallWindow Air...
Power
The reason the tv is turning itself off, because most TVs have a "Protection Mode" that turns the unit off when it detects a failed part inside the tv.
The most likely the tv has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
Being that the TV is under a year old, it should be still under manufacture warranty. Last thing you want do is void the warranty by opening up the TV. Here's some info to get you started on the warranty:
http://www.vizio.com/support.aspx?id=1588
If it not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 42" lcd powers up with sound only - no picture
It sounds to me that the unit has a faulty inverter board which could be due to an overheated/bulged capacitor. I would send in a claim on it to the factory if it is still under warranty.
May 28, 2009 | Vizio VU42L 42 in. LCD TV
Vizio L32 HDTV 10A - Won't Turn On
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Sep 22, 2008 | Vizio L32 32 in. LCD HDTV
Vizio 42 inch tv Power Not working
It's very easy to swap the entire power supply board. If it's out of warranty, what do you have to loose? You can purchase a new power supply board from Vance Baldwin. They are the ONLY parts supplier for Vizio. http://www.vancebaldwin.com/ Once you receive the new board, it's just plug and play. Crack the case (a series of small screws around the back perimeter) and remove the old power board and replace it with the new one. It's that easy!
Jul 27, 2007 | Vizio L32 32 in. LCD HDTV
Vizio GV46L 46 in. LCD Television Logo
321 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
