Question about Brother ML-500 Typewriter
Ribbon is sticking
I have an ML-500 and my ribbon is sticking when I type, so basically I'm typing over the same place in the ribbon. I replace the ribbon thinking it was the ribbon itself, but it is still doing it. The part of the typewriter that turns the ribbon is working, but when I put on the ribbon I get this problem.
Try replacing your ribbon make sure that you have a Brother AX-10 [ 1030 OR 1230] ribbon in your machine. Also try turning your machine on and off a few times, to see if your print wheel is truning. You can also open the lid to your machine, put the black handle back [toward you] and lift the print wheel out of the machine - blow some air into the wheel -replace it and press the black handle back [towards the machine] until it clicks, than turn the machine back on. your ribbon 'driver' the orange knob on the cassette, try turning it clockwise. good luck.
Posted on Jun 17, 2008
    Sergeant:
  • 329 Answers
You may have a wrong ribbon, sometime the small parts where the ribbon turn gear goes into does not match up correctly. Can you turn the ribbon manually by hand, if the ribbon does not turn it will not type....
Posted on Jun 12, 2008
Ribon will not type
it may have come loose from its post or something in the ribbon drive broke
Jul 05, 2014 | Brother ML-300 Typewriter
Hammer doesd not strike
There is a clutch system under the ribbon carrier that has to rotate to move the hammer, see if you can see if this part is rotating, also there is a spring that puts pressure on the hammer. If this clutch is not moving it may need replacement,, or cleaned with alcohol.
Apr 14, 2014 | Brother ML-500 Typewriter
My Brother ML 100 typewriter does not print because the film ribbon does not advance while typing. It keeps striking the same spot on the ribbon and therefore, no typing appears on the paper. If I remove...
I've had several of these ribbon cartridges do this. You might get lucky and get it freed up, but I rarely did. Look in the windows of the cartridge and see if the ribbon is not wound evenly...if it isn't you can try gently tapping the cartridge on a flat surface to attempt to even out the ribbon on the spool. If you are not successful, then replace the cartridge. I had mine for almost 10 years and the cartridge was always the problem. Otherwise the typewriter worked flawlessly. Good luck.
Sep 05, 2013 | Brother ML-100 Typewriter
I just replaced the typewriter ribbon my Brother ML-100 typewriter; however, it does not advance properly so typing does not appear on paper. What is the problem?
Take the ribbon off, see if it advances with the hand feed wheel if not you have a bad ribbon. Type without the ribbon and be sure the ribbon driver is turning. There may be a switch or setting for use of an overstrike ribbon,
DickyO
Aug 28, 2013 | Brother ML-100 Typewriter
When typing, the letters are not showing up well unless it is on double strike. have take printwheel out and changed ribbon but still not striking paper well.
The problem may be the ribbon or the media you are typing on. try typing on a mulit part form, if the copies are good then its the ribbon (OLD) or the paper (GLOSSY).
DickyO
May 06, 2011 | Brother ML-100 Typewriter
My typewriter all of a sudden just stopped typing letters. im not sure if the ink has run out...it wasn't fading or anything before it stopped working mid typing
The ribbon might have fade out, please try and replace the ribbon or check the ribbon selector if is not for stencil cutting. If is in stencil cutting it wont print on the papers as u type. Thanks
Apr 29, 2010 | Brother ML-300 Typewriter
Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Jun 11, 2009 | Brother ML-300 Typewriter
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Typewriter won't work after replaced ribbon
The ribbon is on wrong or now snapped down all the way. Use light pressure to snap it down.
Jan 06, 2008 | Office Equipment & Supplies
Ribbon problem
does the ribbon feed by hand? If not get a new ribbon.
DickyO
Dec 24, 2007 | Brother ML-100 Typewriter
Brother ML-500 Typewriter Logo
154 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
