Question about HP Pavilion TX2510US Notebook
My computer does not seem to boot up when I switch it on...the lights go on on the LED indicators that suggest the computer is working and there is initially a sound, but the screen remains black. It is as if the computer is starting up but seems to get stuck.
    Scholar:
  • 180 Answers
You've got a failed backlight - requires a new inverter assy - not an easy component to replace.
Posted on Jul 08, 2010
I have HCL Ezeebee desktop computer when we boot the system monitor, keyboard, mouse blink for a while and monitor (HCL) show 'no signal' message, and keyboard num lock led not display mouse i
No signal at the monitor indicates (if you know the monitor is working ok) a failure of the graphics chip or graphics card, The lack of indicator light on the num lock LED and the lack of power to the mouse would indicate that there is a major issue with the motherboard.
you can try using another monitor to confirm the problem lies with the graphics, and in the case of the keyboard and mouse, swap them for a usb version, if they work, the Ps2 ports are probably damaged.
I'd be thinking of replacing the motherboard
May 19, 2012 | Computers & Internet
No light comes on in my ge profile pgss5pjxcss
I have the same problem, suddenly no light on mine. I checked the switches and the fuse, all good. The replacement for the LED light is $260.00!
I keep looking for the cause before spending that kind of money for a LED light. Any Suggestions?
Jan 14, 2012 | GE Refrigerators
Power failure,command display (no bootable cd)
It seems that your first boot was on cd or dvd, or may be your hard drive did not detect, to check both of them go to BIOS set up by pressing F2 or Delete on your keyboard to enter set up. When you are in set up mode go to Boot menu (if you can not see boot menu go to advance). In a boot menu select HDD as a first boot and Cd or DVD as a second boot, if you can not find your HDD it means that your HDD did not detect, and you need to replace it with a new one.
Hope it gives you a solution
May 30, 2011 | Computers & Internet
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
Problem booting up
Potential source of problems:
1. The Operating System is corrupted
Reinstall OS with WINDOWS installer CD
2. Your Boot Loader is corrupted
3. AC adapter/Battery not working properly
4. RAM is defective
Thanks, Cheers!
Apr 20, 2010 | HP Pavilion TX2510US Notebook
My HP Pavilion a1050y won't boot up.
So you've checked the supply, but you didn't replace it, right? Sounds to me like that's your culprit. It's not able to supply the current to run the processor (the biggest draw) and the output is dropping too low to run the system. A new supply should get you running again.
Mar 06, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
Computer won't turn on
check all led's. then make sure your switch is connected to the motherboard properly. if a conection to the switch is loose (which is what it seems) it wont register to start the boot process.
Feb 24, 2008 | Mach Speed (S755) Motherboard
Flashing Lights when powered down
The flashing LED is because your system is in "sleep" mode. By default windows Vista puts your computer in sleep. What this means is it doesn't shutdown the power completely it leaves a little going through certain computer components (more specifically the ram) to speed up the boot time when the power button is pressed again.
In XP a the default shutdown scheme is a complete shutdown where power is turned off after the shutdown process is done. If you are using XP you are putting your computer to sleep when shutting down.
As for the boot problem. Newer motherboards have an LED on the actual board to indicate that it is receiving power. If it is of either the power supply switch (at the back of the case) if off or the motherboard connection is loose and the shaking makes it fall into place. (Shaking is usually not necessary and indicates a problem...)
There are a few possibilities I can deduct from your description:
  • the connection from your power supply to your motherboard isn't properly seated and is causing this
  • the power supply switch (not the case switch) is being  turned off and results in the computer taking a few seconds before the internal LED become solid
  • ... the dreaded sign that the power supply is failing and is on it's last legs...
My suggestion is to check all connections and if that doesn't work borrow a power supply from a friend and swap them to see if it boots properly.
(If a friends with a spare power supply isn't an option a local PC repair shop should be able to help you out... but probably for a fee...)
Oct 28, 2007 | Computers & Internet
HP Pavilion TX2510US Notebook Logo
168 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
