Question about Rival S16RB Electric Skillet
Removable skillet pan has bubbled and teflon is coming off
  • 5 more comments
  • Charlie44 Apr 23, 2008
    The teflon on my pan bubbled right away also. The pan was preped acording to the instructions before using it. I don't own any metal utensils, and use only teflon safe sponges to clean. I love the skillet, but what caused so many customers to have this issue?
  • Anonymous May 14, 2008
    I am disgusted this this removable pan, also. I didn't even put it in the dishwasher. I washed mine by hand. The coating bubbled up after about 5 uses. My husband even noticed the awful surface from across the room and asked me what happened. This is awful and I think Rival should be ashamed to put something on the market as badly as this pan has turned out to be. I think Rival should mail out new skillet pans. The base, etc. is okay but certainly not the cooking pan itself. I, too followed all directions concerning prep and cooking utensils. I am going to write to see if Rival is going to replace the cooking skillet pan itself. Will update later to let everyone know how it turns out and what their solution is.
  • jaygh Jun 22, 2008
    Our pan has bubbled also and the teflon is flaking off. Is there a replacement pan available?
  • ewolfe Jun 28, 2008
    Well it looks like were all together on this one. I found the customer service for Rival products. I will be calling on Monday to complain about mine. If all of us call at once maybe we will make a bigger impact!!!!
    The Number is:
    1-800-323-9519
    Please post your info on what if anything the company did!!!!
  • Anonymous Sep 08, 2008
    Also never used metal--only wood/teflon safe utensils. Rival already replaced one pan (was still under warranty). Same happening again. No problem with cooking, heating, etc.
  • Anonymous Sep 29, 2008
    I had the same problem. The non-stick surface chipped and came off. I called the number someone else listed...800-323-9519 and they were very helpful. They are sending me a new unit. It was great customer service.
  • mike2655 Feb 27, 2009
    yep...me too!! removable skillet pan has bubbled...I will call and see if they are willing to help.
I had the same problem. The non-stick surface chipped off and is actually sticking to our food. I didn't ever use the dishwasher and washed by hand. Also using plastic utensils. I called the number someone else listed...800-323-9519 and received excellent customer service. Rival is sending me a new unit.
Posted on Sep 29, 2008
I had the same problem. The non-stick surface chipped and came off. I called the number someone else had listed...800-323-9519 and received excellent customer service. They are sending me a new unit!
It got so bad I just threw the pan away.
Posted on Apr 23, 2008
Model S11P Electric skillet loss of Teflon
I'd contact the manufacturer and see if they'll send you a replacement. That's not normal.
Aug 30, 2012 | Rival Kitchen Appliances - Others
Are teflon electric skillets dishwasher safe
No, don't put anything Teflon in a dishwasher, it will turn the teflon gray
Jun 10, 2010 | Rival S16SG Electric Skillet
Heating element won't heat. Control light comes
your element is shorted
since the elemen t is welded and fitted to the bottom of the pan it can be fixed but should not be
my advise get a new one
rival will just say it has water damage
Oct 08, 2009 | Rival S16RB Electric Skillet
Teflon coating bubbling in spots
Sadly there's not much you can do here then. If it has started to bubble it only takes one swipe from a utensil to break it open and I had to get rid of my 12 year old tefal pot because of a very similar problem.
Teflon sprays exist on the market to spray light coatings on mechanics. However it is not fit for utensils or anything that may be consumed out of. You should just invest in a new set.
Please rate thanks.
Jul 24, 2009 | Kitchen Appliances - Others
Rounded bottom on frying pan
I did a CPR move on the bottom of my pans by turning the pan upside down and hanging the handle off the edge of my counter. I then pushed down with my palms. It was easy.
May 20, 2009 | Rival S16RB Electric Skillet
Non sick finish coming off
I posted a comment on a solution?? but want to e-mail you too. Line the pan with heavy duty aluminum foil before frying food. It's better than having teflon flakes on your meat.
Mar 10, 2009 | Rival Kitchen Appliances - Others
Need a price for a replacement... non-stick pan for the S16RB
Call the customer service number 800-323-9519. I had one that the surface started to bubble up and they are sending me a new unit! They gave me excellent service!
Sep 03, 2008 | Rival S16RB Electric Skillet
Rival Electric Skillet S16G
Hi, Your skillet is either defective or someone has left it on high with nothing in it. Either way, if it is still under warrenty, I would try and return it. As there is some debate about the toxicity of teflon, I would be very careful about using this unit any further.
If you are going to keep the skillet, try using steel wool to remove the loose teflon, maybe even sanding it all off if you want, then polish with fine steel wool and use the skillet as a regular uncoated electric fry pan.
Hope this helps, and if you found this response satisfactory, please vote. Thanks and good luck.
Mar 02, 2008 | Rival S16SG Electric Skillet
Non-stick surface coming off
I find that in viewing this site that the listed " solution" is not a solution at all! This skillet has a defective design and coating and should be recalled!
Sep 03, 2007 | Rival S16RB Electric Skillet
Rival S16RB Electric Skillet Logo
274 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Ric Shull
Ric Shull
Level 1 Expert
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
