Question about Dometic Rooftop RV Air Conditioner
, Compressor start capaciter MFD value: roof top RV Dometic unit
On a roof top RV Dometic unit, what is the value of the compresor start capaciter? The label in very hard to read. Unit is on a 30 foot 1996 Pinnicle by Thor.
    President:
  • 1,515 Answers
Hi, I did some research and found nothing on the a/c unit. If I had the model and serial numbers from the condenser and compressor this would help me. This would be a run capacitor doing the start up, dropping out the start relay and keeping it running. If you have only one run capacitor and its a dual, will have 3- female spades coming from the top, with marks that say Fan, C for common, and Herm. for compressor. If it has only one capacitor with2- female terminals, several places to connect more than 2 wires, its a single cap. If it just runs the compressor, it could be a 370 volt x 20, 25, 30, 35, uf?? If its a dual it could be a 370 volt x 5 u f for the fan and the same , 20, through 35 u f or microfareds. The best way to find out is to take off the wires on it, and make sure you draw a diagram so you know they are right, and take it to a appliance parts house and let them check it to see what they are. Larger units can have a 440 volt x 20 to 35, 40, 45 and so on. Your unit is not that large, so it will only be 370 volts as far as voltage, but the u f value will need to be checked with a meter that will check the value of these and give you a number such as 4.99 u. f. and you will no its a 5 u f. It may be higher like 5.24 u.f.and that is OK. Make sure the capacitor has no oil leaking from it or its not swollen looking or distorted in anyway, it will be open or shorted out. Please let me know if I have been of help to you when you go to rate me, please be kind. I will be here if you need my help if you are having problems with the compressor not starting.
Sincerely,
Shastalaker7
A/C & Heating Contractor
PS If this capacitor is black plastic and mounted on the side of the compressor, it will be a start, run capacitor with 2 wires. It snaps in a metal type holder you will need to take it out and check the terminal area it was connected to and remove it. If only 2 wires, it won't make a difference what side the leads hook to.
Posted on Jul 03, 2010
Testimonial: "This is exactually the information I was looking for. The paper label on the black plastic cse was faded, and I wasn't sure of the u f range this comperssor needed. Thanks, G"
  • Robert Horton
    Robert Horton Jul 04, 2010
    Glad I could be of help to you. Thank you for the great rating!
    Have a happy 4th of July
    Shastalaker7
How can I tell if the compressor is coming on on my Coleman 13500 roof top A/C unit? It blows air but not cooling. Thanks
When the compressor starts you will hear the unmistakable noise associated with it...there is a definite hum from the compressor...check the t-stat on the unit... they often go bad..
heatman101
May 19, 2011 | Dometic Rooftop RV Air Conditioner
Have a Quick Cool RV roof unit compressor:
Try ( www.dometicusa.com) site and they have dealer locator on there site for wherever you are.
May 17, 2010 | Dometic Rooftop RV Air Conditioner
My roof top RV air conditioner is dripping water inside my RV
Check run-of on roof & see if it's been reduced lately, it may just be a plugged drain at base of unit on roof.
Jul 29, 2009 | Dometic Rooftop RV Air Conditioner
I''ve been working on this thing for three weeks now. It is a Dometic Duo Therm model 57915.531 roof top ac on my rv. It will not run. This is what i have done so far: replaced the thermostat, there is...
check the compressor winding resistance from common to start
start to run
run to common
the two lowest should equil the highest
also check shorted to ground
check the capacitors the go bad a lot
May 16, 2009 | Dometic Rooftop RV Air Conditioner
Compressor
pls check compressor capacitor and compressor termonal connection start the unit check the voltage at the compressor terminal if is ok means copmressor need replcement
Apr 27, 2009 | Dometic Rooftop RV Air Conditioner
Compressor needs replacing
Good luck, I'm in the business and it's virtually impossible to find just the compressor for rooftop rv units. You might be able to get one through and RV dealer that sells parts as well. Also, contact dometic. Usually the only time a compressor is replaced is when the units are still in warranty. Let me add one more thing. Because of the price, it's more economical to replace the whole uint since most of these units are below $800 total price.
Mar 21, 2009 | Heating & Cooling
Compressor tries to start but want
hi,
you have to run a contractor grade extension cord(10-12 gauge) from your rv to run those or theyll do that, the lower the gauge the better, best bet is to plug the rv directly into the outlet, if you cant, get the shortest and thickest extension cord you can.
Aug 21, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
214 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
