Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
I have a 1hp 115/230 phase 1 sprinkler pump what size pressure switch do i need 20/40 or30/50 ?
  • 760 Answers
The pressure switch needs to be sized for the pressure and the motor current. The pressure would depend on your piping system, and hao many sprinklers you have on a section. You can buy a pressure switch that is adjustable, and you can set the pressure you need. You also must be sure the current rating (amps) of the pressure switch can handle the motor current (amps) there are is a wide range of switches available. You can't go wrong with a square d though. Available Home Depot, graingers, electrical supply etc.
Posted on Jul 04, 2010
My 8 Yr old 1hp jet pump model JRD10 cycles on and off when i try to use hose at facuet?
I think the pressure switch is cycling your pump when there is a low demand. If your system has a pressure tank, it is waterlogged (has no air in it). If you shut down you system, drain the tank, and the restart you system, it should work. Most tanks are made to be pressurized to a certain pressure before starting up your system. Some tanks have a 'tire valve' on them for pressurizing with air.
Oct 29, 2014 | Goulds Pumps Goulds gt10 1 1 Phase...
What is gpm flow for this pump
for the 1hp size this pump is capable of generating 76 gpm at 0 feet of head pressure of course it goes down from there as you increase head pressure (lift)
May 28, 2014 | Pentair Pinnacle High Performance 1 HP...
Not enough flow and pressure to run sprinkler system
pressure in centrifugal pumps depends on the number of impellers in the pump housing, the clearance of the impellers to the housing and the power of the motor to drive the impeller/s
volume flow is also important as a pump without a high output will not produce pressure
check the jet size at the foot valve that is used to help lift water to the pump
It is a jet pump and will have a smaller line back to the foot valve for that purpose
next wil jet pumps if there is too much flow to the outlet , the pressure required to help lift the water to the pump is reduced and the volume is also reduced
you indicate 4 sprinkler heads per zone but how many zones are operating at one time
check the expected delivered volume for the new pump against delivered volume of the old pump as a starter to find the reason for the poor performance of the new pump
check also the rpms of each pump as that also has a bearing on volume produced
Mar 26, 2017 | Flotec Pump FP4032-10MK
Not putting out enough pressure or flow to pop up sprinkler heads
Have you fixed this problem?
Q? Did you replace an existing pump. And what was the model and did it work.
Q? If its the same size as the fp4032, has anything else changed? Is there a filter that needs checking.
hydraulically to work it out I need the distance from pump to water, height and size of pipe. Distance you are pumping too, height and size of pipe. And what the "four heads are"? Nozzle size etc. To work out a flow/pressure rate.
May 10, 2013 | Flotec Pump FP4032-10MK
I have a one hp AO Smith electric pump motor for my sprinkler system which is approximately 5 years old. Well point is clean and all sprinkler heads have been replaced. I am not able to get distance from...
If you replaced your sprinklers, did you use the same size nozzles as the original heads?
I need more information and I can help you with a well/sprinkler system problem.
Gary
Jun 18, 2011 | A O Smith Motors A O Smith 1hp 115/230v Ur...
I have an aquamate pump and when i connect it to a continuous sprinkler it stops and starts contiuously
The pump is putting out too much water for the sprinkler.
You can raise the pump shut off pressure at the switch until it is higher than the pressure that the pump runs at with the sprinkler operating. You should have a surge tank connected to the system to give the pump time to balance with the sprinkler.
You can use more water with the sprinkler. This could mean adding another sprinkler or increasing the nozzle size of the existing sprinkler.
Dec 05, 2010 | Garden
Need head pressure on 1hp shallow well pump SDTS10
reducing the pipe size helps build head pressure.
Mar 18, 2010 | Plumbing
I have 1 and 1/2 horsepower sprinkler pump that wont prime. As soon as the end piece fills, it will empty if I open the end to the sprinkler.
I don't know what is your system set up. However, the system set up should be the following;
1. Your 1-1/2HP sprinkler pump must be installed at
a fix location nearest the water source. (Complete
with power and plumbing lines.)
2. At the end of the suction line is a vertical check
valve with strainer.
3. The suction pipeline must be connected to the
suction port of the pump.
4. At the discharge port, a flow control valve tee must
be installed. The flow control valve tee top is
covered with a plug, which serves as the priming
port when opened.
5. After the flow control valve, connect a short nipple
so that you can put a gate valve to stop the water
flow or allow the water to flow. You may connect
a pressure tank at this point or you may connect
the pressure hose going to the sprinkler.
6. To prime the pump, open the plug at the flow
control top. Fill it full with water, replace the
priming port plug.
7. Turn the flow control valve to full closed position.
8. From full close position, switch the power on.
9. The pump now run on and off due the pressure
switch setting. Slowly open the flow control valve
such that the water pressure remains steady.
10. Take note of the pressure.
11. Shut the power off, and connect the sprinkler
pump hose.
12. Put the power back on, and allow the pump to
run with the sprinkler.
Under this set up, you can run the sprinklers when your pump is running. Hope this will solve problem.
Dec 08, 2009 | Plumbing
2009-10-05 I have a motor in my garage that serves my water softener, sprinkle system, and outdoor faucets in conjunction with a well pump. I live in Virgina Beach, VA. The motor is an A.O. Smith machine...
sounds like just pressurizing ur holding tank pumps come on and off depending on how sensitive ur pressure control is normal operation of unit
Oct 07, 2009 | Plumbing
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
136 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
