Question about Ryobi Garden
Replacing fuel line on ryobi 775r trimmer. when i removed old line and filter, the plastic fitting with the filter protruded about 1/4'' out of tank and was held by plastic retainer ring, now i can get the fitting and line to protude more than about a 1/16'' of an inch- not enough to accept the retainer ring- is there a trick to forcing/pushing the filter fitting back through tank? I can't get my fingers or anything else i've tried on the filter fitting to push it through the tank.
First off, get a piece of fuel line longer than you need for the job. With the gas tank removed, wrapped in a towel and put in a vice to steady it I fed the gas line in from the outside of the tank to through the fuel hole (where the gas cap fits on). I carefully worked the fuel line onto the filter until it was all the way on (touching the bottom of the filter assembly). I then gently pulled on the line feeding it through the hole. Then with gentle pulling, twisting and nudging from inside and outside the tank I worked the fuel filter nipple through the hole on the bottom of the tank until it was flush and secure.. Once the filter and fuel line were secure in the hole on the bottom of the tank, I then worked the secure ring up the fuel line and worked it onto the filter stem until it was snug. I then fed the line through the appropiate holes in the engine, trimmed it to size and fitted it on the nipple on the engine.
Posted on Jul 15, 2010
Fuel line for ryobi
hello sir, fuel line routing for ryobi,poulan trimmers, looking at machine from left side,front green line from tank to bottom of port on primmer bulb. rear line from tank which has filter inserted through tank with small white ring pushed up aginst tank & filter fittings, goes to port at bottom of carburetor.top line from primmer bulbgoes to top port of carburetor. that is the way thay go on.it is important to make sure you have the same fuel line I.D.3/32 and O.D.3/16 are very important! also if old line dissolved it will get in carb. and clog ports & small screen inside.clean inside of carb. with carb. cleaner & air pressure. to get your parts and numbers ,go to mtdparts.arinet.com, parts,791-683398,fuel line assembly,this is for most fuel line trimmers~~~hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ``
Feb 12, 2012 | Garden
Fuel lines rotten
There are two fuel lines, a supply and a return. The supply line is the long one and hangs in the tank where it can follow the fuel as the machine is moved around, it often has a weighted filter attached to it. The return line just protrudes into the tank from the carb. To sort out the pipes, fit them and operate the primer bulb. The fuel should be sucked into the long tube and return through the short one. There are special slilcone rubber tubes made especially for these small machines. Normal plastic tubing goes hard, will not move around with the fuel movement and eventually disintergrates.
Jul 18, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
How to replace fuel lines on model725r ryobiweed wacker
There are usually only two fuel lines on a Ryobi motor, a supply and a return line. The supply line is a long one and is designed to move around the tank as the unit is moved around, some hafe a weight with a filter on in the tank. The other line is shorter and just protrudes into the tank, this is the return line. The piping you fit should be the special silicon rubber pipes as these are fuel proof, normal plastic pipes become hard and do not move around in the tank, and eventually crack or disintergrate. Replace the new pipes the same as you remove the old ones, if you go wrong, just change the pipes around on the carb, you will see if you are sucking air with the primer bulb.
Jun 30, 2011 | Ryobi 15" Electric Factory Reconditioned...
I need the fuel/oil mixture for Ryobi 31cc 775r gas weedeater. Also the diaphram for the fuel line replacement.
The fuel/oil mixture is 40:1. That is 3.2 oz. oil/US gallon. Now for the fuel lines:
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Jan 09, 2011 | Ryobi Garden
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
Fuel line routing on ryobi 775r
One line ( the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the lower port on the carburator. The second line goes from the fuel tank to the bottom fitting on the primer bulb. The third section goes from the top port on the primer bulb to the top port on the carburator. Hope this helps and best wishes.
Sep 01, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 775r gas trimmer stalling when tilted
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Jul 17, 2009 | Garden
Ryobi 768r fuel line
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
Mar 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 700r gas trimmer, replace old fuel lines
To leemineres, if hoses are on right and unit still stalls after starting initially you probably need to disassemble carb and clean out using spray carb cleaner. May be sticky needle valve, or partially plugged port or jet.Could also be hole in diaphragm. Gasket and diaphragm kit would be good to add when you take apart, even if diaphragm does not have a hole.
Jan 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
375 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
