Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidaire refridgerator has musty dirt smell odor
We live in a new house and we bought our Fridgidaire Refridgerator 4 yrs okay. It's a side by side Gallery series with the Pure Filter 2 Water Filter system. We noticed a musty dirt smell. We clean our unit out weekly but flabbergasted a to what's causing this smell. WE've never had this problem before out of any of our refridgerator units.
dididsaythat
  • 291 Answers
SOURCE: DEFROST SEEMS STUCK
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Posted on Sep 15, 2007
Basti
  • 1447 Answers
SOURCE: leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Posted on Jul 14, 2008
  • 126 Answers
SOURCE: Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
Posted on Jan 12, 2009
Sea Breeze
  • 4654 Answers
SOURCE: side by side only dispenses crushed ice
Below is the link to parts the manual for the model listed now we need to determine if the switch in the door is bad or wiring fault.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
This link below is a Q&A's and also very helpful for parts and answers
http://www.applianceaid.com/refrigerator.html#freezing
Let me know what you would like me to do. Fact is everything you need is on the pdf if your part# and MFG. Is correct. Let me Know, Thanks, Sea Breeze
Posted on Feb 02, 2009
  • 40 Answers
SOURCE: water pooling inside of refrigorator
sounds like the drain line for the defrost cycle is plugged. the water is supposedto end up in a pan under the refrig. the drain probably needs to be defrosted and cleaned.located behind the back panel in the freezer compartment
Posted on Jan 22, 2010
Saging door
You should be able to adjust the door hinges very similar to a normal household door. You may have to unscrew the hinge and reinsert. This would definitely involve two people.
Sep 05, 2012 | Frigidaire FRS3R5EMB Side by Side...
I purchased a Kitchenaid Refridgerator 6 months ago. I changed the filter at the bottom about 3 weeks ago. Ever since then, my refridgerator has a bad odor. I have completely cleaned the refridgerator and...
If you purchased this machine NEW 6 months ago, everything on it is under warranty. You should contact the selling dealer to verify you are entitled to a free service call. Changing the filter is routine maintenance and in no way should affect the warranty.
Oct 25, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerator and freezer musty, freezer burned smell? ?
they should be washed every2 months use baking soda and a box of fridge charcoal
thumbs up
Aug 17, 2009 | Frigidaire GLRS264ZA Side by Side...
I have the same problem with my Kenmore refridgerator
To completely clean a frig of bad smells you will need to remove the back cover of frig and freezer compartment to access all areas. I operated a used appliance store for years and had all manner of stinky refrigerators to deal with so what we did was take out all panels and clean out with bleach and water solution. This took care of most odors. Hope this helps.
Jul 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Musty smell/taste from water dispenser in refridgerator
The icemaker has mold or mildew in the little nooks and crannies. An appliance parts supplier might have something available for flushing but I am not sure. There might be something in the ice bin or on the auger contaminating the ice and water as well. Check back to the source as the water supply filter may have accumulated something unpleasant while the ice maker was down. Hope this input helps.
Dec 30, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Fridgerator not cooling
I have the same problem. Freezer is okay, but refrigerator is not cooling.
Mar 24, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire the refridgerator is not cold enough. It stays at 60 degrees, I don't know the model because it was torn off inside the fridge and the owner's manual did not come with the house when we bought...
Have one similar and found out the compressor goes out on them about a year and half after purchase. You can buy another compressor but the likely hood of it going out again is likely. Sorry but we bought bad fridges. Never again will I buy a Fridgidaire.
Jun 10, 2008 | Frigidaire Refrigerators
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
116 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
