Question about Seiko Mantel Clock
I have a Seiko Westminster Whittingham Clock, which keeps perfect time, but the pendulum won't swing for more than a couple of minutes. Does anyone know what's causing this? Bob
    Habit-Forming:
    New Friend:
  • 31 Answers
There's probably a missing or damaged part that is keeping the pendulum from swinging the way it should. I would suggest having a professional look at it. They would know how to open it up and fix it properly, and then you wouldn't have to worry about it potentially being damaged during the repair. I know I'd trust a professional before myself any day, especially with something I don't know very well.
http://www.midcoastclock.com/cleveland_clock_repair.html
Posted on Mar 16, 2016
    Genius:
  • 1,970 Answers
Mcdevito75 here, I would figure the pendulum serves 2 purposes, 1 it acts like a seconds hand on a watch and 2 more important it acts a s a counter weight keeping the clock in Balance. It sounds like the Pendulum mechanism needs cleaning and or adjustment, look for a small watch repair shop in your area, they can advise you on a clock repair shop in your area, or you can always check with the repair service directory right here at fixya, bottom of page, click on repair service directory the watches / clocks.
Posted on Jul 03, 2010
How can I completely silence the chimes of the Seiko Westminster Whittingham wall clock?
I looked this up, not sure if yours runs on batteries, but here's a step by step to the chimes.
http://blog.princetonwatches.com/how-to-setseiko-chiming-clocks/
Nov 14, 2015 | Home
I inherited a Seiko Westminster chime clock. The time is perfect but the hourly chimes are 3 hours behind. How can I synchronize the two?
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Sep 21, 2015 | Seiko Mantel Clock
Pendulum does not move
Good details! Go to Timesavers.com
You can find a replacement pendulum unit there. Your pendulum mechanism probably has a bad coil. The coil is extremely difficult to repair.
Dec 04, 2013 | Sterling & Noble Scroll Pendulum Wall...
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
Jan 01, 2011 | Watches
How do i synchronize chimes with clock on westminister whittington clock .
The Westminster/ Whittington clock means that it has 2 or 3 settings.
1. Silent
2. Westminster Based on the music My redeemer liveth by Handel
3. Whittington
Set the clock onto the westminster setting, this is the easiest. At quarter past the hour it should sound 4 notes. The half past should be 8 notes. Quarter to the hour should be 12 notes and the hour should be 16 notes then the striking of the hour. For example on 8 'O clock you should hear 16 notes then the clock should chime 8 times. Sometimes if the hour is out just gently stop the pendulum, check what hour the clock is striking then without taking the hands off move only the hour hand to the hour. Do not do this with the minute hand.
I hope this helps you! If you are not sure please email me yvonne.finch@gmail.com I fix these clocks.
Apr 30, 2010 | Seiko Mantel Clock
Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
Jan 28, 2010 | Watches
Seiko kinetic
I habe seiko kinetic work and stop work
Feb 07, 2008 | Watches
Home Logo
654 people viewed this question
Top Seiko Home Experts
k24674
Jimmy Accardi
Are you a Seiko Home Expert? Answer questions, earn points and help others
